Making mortises using drill press/Forstner bits
wilbur
>I'm getting geared up to make a workbench. I've made a smaller worktable, but had some issues making the mortises that I would like to avoid this time around. The first time, I used my drill press and a 1" Forstner bit to clear out most of the waste. The problem was that the walls of the mortise always seemed to have too much of a "scalloped" edge where the drilling overlapped. I spent so much time paring the walls of the mortises smooth that I felt like it would have been faster chopping them by hand.
Any tips on avoiding this? I tried various levels of overlap between drilling, but always wound up with more scalloping than I wanted.
Using a router is probably not an option as the mortises I'm planning to make are pretty deep.
Re: Making mortises using drill press/Forstner bits
Can you route from both Top and Bottom?
Re: Can you rout from both Top and Bottom?
wilbur
>Not really -- these are not going to be through tenons.
Patrick Jaromin
>Have you considered making the piece from a 3-piece lamination and simply notch the middle lamination before glue up. If you already have thick stock, you could resaw it into thirds first and again notch the center piece.
Bob Entwisle in NJ
>How about routing them from one side and then a bottom bearing bit from the other side?
Re DUH ignore my previous post,
Bob Entwisle in NJ
>I don't know why I was thinking through holes......DUH......
Re: How about..... *LINK*
Bob Entwisle in NJ
>use a router and straight bit to start the mortice and then use one of these long flush trim bits to complete it? I guess the issue is how deep is the mortice?
http://www.amanatool.com/routerbits/pattern-template-routerbits-45481.html
Re: How about.....
wilbur
>Hi Bob,
The mortises are going to be about 2 1/2" deep, so beyond the reach of the longest router bits I can find.
I may rethink the design, though.
Re: How about.....
Carol - now in NC Nebraska
>Consider end mills. They come in a variety of lengths, easily able to cut to 2-1/2".
2 flute, right hand twist for mortising. The diameter will have to match your collet - most likely 1/2". Your guide may have to be a template guide screwed into your router base plate. No bearing on end mills. And you will likely have to step down into a mortise that deep with a succession of bits, as the end mill able to reach deep enough is longer than your router's ability to retract the bit above the base plate. You may already have a spiral bit long enough to begin the mortise. Follow up with the end mill.
Oh, extract waste often. That deep and it will build up, unnecessarily heating the cutter.
Hope that gives you another option.
