Finishing Cypress?
Finishing Cypress?
Finishing Cypress?
>I got a nice piece of 8/4 cypress for use as a seat blank (I could have used 8/4 poplar or 8/4 pine). I know the pitfalls of staining and finishing pine - but I have never worked with cypress before.
I usually use dye to get a more or less uniform coloration if I am mixing woods on a project - but I have a few quarts of Varathane that my sister had left over from her floor project. I'd like to use it. Any problems? Any particular finishes to avoid with cypress?
Re: Finishing Cypress?
>Cypress can handle any finish. I have used pigmented stain, oil, oil poly, water borne poly, solvent lacquer, oil poly over oil stain, and water poly over oil stain with no problems. And it takes stain with no blotching. If using a water based stain, pre-wet the wood.
Clint
Re: Thanks
Jim Dillon
>JL,
On a more limited basis, my experience mimics Clints. No problem with stain (Sikkens), oil/varnish (Tried and True) or Minwax wipeon poly. And no signs of blotching. Though relatively soft, it is a nice wood.
Jim
Re: Watch Out With Poly
Joe Doker
>I've used cypress quite a bit and have had several instances where oil based poly (Minwax) took a very long time to dry - on the order of days! Once was a cypress floor. The problem was worse on the darker, more resinous, boards. Once dry, subsequent coats were no problem. I now apply Seal Coat (shellac) first to avoid the problem.
>Thanks for the advice. I'll try finishing the bottom first.
