Glueing 8/4 Walnut to 4/4 Maple
>I'm building a Foosball/Soccer table. I figured I'd go all out and, like all other projects, spend more than if I just went out and bought a premade one at Sports Authority.
It's basically a fancy box 4-sided, sort of like a waterbed frame. I'm using 8/4 walnut, with hard maple highlights. The sides will be be glued up slabs roughly 50" x 20" x 2".
I can't seem to find any 8/4 hard maple (got plenty of 8/4 walnut and 8/4 soft maple, but only 4/4 hard maple) so I thought I'd simply rip some 2" wide strips of maple and sandwich them in with the walnut for the glue-up.
Think of some wide walnut with a few white "racing stripes" running down the middle.
Anyone see any problems doing this? How about the glue... just use Titebond II ? Am I looking a problems with shrinking, cracking or anything like that if sticking the maple between the walnut like that? Or should I just keep it all walnut?
I'm not completely set on the maple stripes idea. I wasn't going to at first, and then though since I'll be gluing up a 20" wide slab, that I could be cool looking with stripes, but I won't if it's going to cause trouble later.
Yes, I'm building a heirloom (hopefully) table soccer game that will weigh as much as a small car :) I've got to build something strong enough to survive the future 180-200 pound teenage boys (my son and his friends in 7 years) using it.
Happy Woodworking!
Re: Glueing 8/4 Walnut to 4/4 Maple
>That should work Mark. The grain orientation will be the same so expansion/contraction shouldn't be a problem. Just get good glue coverage with TB II and you should be fine.
Tom
Dale Lenz
Dale Lenz
>Agree with Tommy, with the exception: I'd use regular Titebond over the ll. It has been my experience w/ll, I get more glue creep.
Your mileage may vary. Dale
Joe in a Cleveland suburb
>Hi Mark.
Just wondering out loud here... would it be easier to just route a groove in the walnut then do an inlay strip of maple to get the racing stripe? Then plane it flush and smooth?
I probably don't understand what you are doing though...
Foosball? Geez. I remember that in smoke filled bars years ago. People still play that?
Joe
Re: Gluing 8/4 Walnut to 4/4 Maple
David Yoho
>Joe, I was thinking the same thing.
Maybe I'm not understanding the intended part Mark's making. If it's the for the sides of the table and he simple wants a maple stripe in the center of the 8/4 walnut, I'd probably cut a groove about 3/8" to 1/2" deep and as wide as wanted with a dado set and inlay strips of maple into it. If this is for the "playing field", I'd still do the same thing. Since the hard maple is harder to come by and the walnut is abundantly available, this way makes more sense to me. Besides, then there wouldn't be any worries about difference in expansion rates of the two woods, and would really simplify the whole construction process.
David
Thanks... here's a pic
>Thanks for you help guys.
Here's a pic from SketchUp of the idea. There will be two of these (sides) and two more for the ends. I've got the table in SketchUp but it's not quite done yet.
Happy Woodworking!
Carol Reed - in Nebraska
>I made my work bench nearly twenty years ago and face glued cherry, walnut, and maple for the top. Titebond II. No problems.
Go for it.
Re: Thanks... here's a pic
marc rosen
>Hey Mark,
I did the opposite of your approach; I made a 3/8 inch accent strip of walnut to make my 18 inch square night stands. Finished thickness was 3/4 inch though, not as thick as you want. I used Titebond II and the results look great. I should post pictures someday but I'm lazy.
Man, I used to love playing foosball too. Went to a few national championships when I was in college in the late 70's. Had a table in my basement for a long time.
Marc
