Wenge fading ?
Wenge fading ?
Wenge fading ?
Link Van Cleave
>Anyone have any experience with Wenge fading. I have a friend who says he has had this happen to him. He said it went to grey and then even lighter. I have never heard of it. It would be nice if it stays black for the project I am working on.
Link
Re: Wenge fading ?
Yup...Also....
HC Sakman
>Hi Link,
Wenge and especially bubinga fades when exposed to extended period of strong sunshine, meaning at the lower parrarels closer to Equator. Initial linseed oil treatment helps.
Chico...
Re: Wenge fading ?
Re: Wenge fading ? *LINK*
Keith Newton
>Yes it is true. The more windows in the space where your work ends up, the faster it will happen. I have some friends whom I made a couple of tables for which I used wenge for the legs, and bubinga for the tops about twenty years ago, that still look great, but both are in rooms with very little window space.
Yet I was out at John and Robyn Horn's place last night. This is virtually a glass house, and while it has 11' overhangs for the eves, they have a set of very nice wenge chairs which have faded in less than ten years.
You may be able to get better service with a pigmented stain on it, but I believe that even dye will fade eventually.
I wouldn't put much faith in UV blockers in finishes. Even the best window tinting made for blocking UV only improves the situation 100%. That is to say, that if the Horns chairs faded in 10 years, the best window UV would slow it down, but 20 years later, they would both be to the same level of fading. I have not ask them, but they probably have UV protection on all of their glass. They didn't cut any corners when they built that house.
She has a book out which has the room I am speaking of on the cover, so you can see it by clicking the link.
http://www.woodturningcenter.org/store/makershand.html
Re: Wenge fading ?
Wenge fading ?
Link Van Cleave
>Thanks guys.
My friend told of a table he did where the through tenons on the top were wedged with Wenge. The surrounding wood was mahogany. At first it was a dark contrast but now a few years later he said it is actually a light contrast with the mahogany. New one on me. Only used the stuff enough to know it has the worst splinters in the history of wood and the dust will give you a rash.
Link
Re: Wenge fading ?
ebd
Re: Wenge fading ?
ebd
>The wenge might be getting lighter, but in my experience mahogany gets much darker with time. If all he is judging by is contrast...
Re: Wenge fading ?
Re: Wenge fading ?
Keith Newton
>It is true that mahogany will darken fairly rapidly initially, but it will peak, then start going back the other way with exposure to much UV.
I have a piece which has a mahogany base, with some cherry, and some wenge. The mahogany reached a nice dark brown within a few weeks while the cherry was still pink. It was in a gallery window situation, so it was getting a lot of exposure. Before long, the cherry was darker, and the mahogany had started loosing the umber shades, while heading into raw sienna shades. I am happy to say that the wenge is still black.
I don't know if any of you have seen this, but I have gotten some 12/4 wenge before that when I cut into some of them, they were only black for about the first 1/4", while the middle was as golden as Southern Yellow Pine. My jaw dropped the first time I saw this. It only took about a week to turn black after exposure to the air.
