Router questions.
Router questions.
Router questions.
gnd
>Hallo all,
I have been using a Hitachi M12V over the past week (first router)both by hand as well as in a table. Couple of questions:
1) While using it handheld, the router does not plunge easily - it feels like something is sticking. With some effort it gives and plunges - feels like the plunge rods need some kind of lubricant. If this is the problem what sort of stuff do I put on it. Any other had this problem? How did you sort it out?
2) When the router is in the table (no dust collection) the chips fall all over it - and when I turn it over to use handheld and lot of dust comes out of its innards - is this okay or should I be covering it with something when it is in the table?
TIA for any light you guys might shed on this issue
Re: Router questions.
Mark in Whitby
>You can disassemble the plunging mechanism somewhat and give the rods and pieces a good cleaning. Maybe a very little light grease (lithium grease I think its called) but NOT allot. Lubricant will just attract more dust and chips.
No worries on the table mode. It's the nature of the beast when used up side down. A vaccum or some dust collection would help.Just try to run out the router when switching back to hand held mode to get the dust and chips cleared out before cutting.
>I don't have any specific answers and have never seen your router up close and personal, but I have read that virtually all routers are designed to operate in the upright hand-held position. There have been a number of comments here that some people treat them almost as a disposable when they are operated in a table. Since the ports on them are designed to keep debris out when they are right side up, they may do a poor job when they are up side down. There may also be issues with the bearings. Some may be deigned to support the weight in one direction, but not the other.
So, with the proliferation of router tables, you would think someone would have designed a router that is ideal for that purpose. If they have, I have not seen one promoted as such, but that does not mean there isn't one.
I would think excellent dost collection would help to keep the debris out of the motor, but you would have to arrange it to suck the stuff away above the motor, not let it fall and take it out at the bottom of the enclosure. Wonder if there is a fan built into the unit you could reverse to blow air and chip out of the bottom?
Router Lube
Curt Harms
>I have a PC 8529 that had a bit of a sticky plunge, not bad. I cleaned the plunge rods and gave them a light spray of Teflon spray from Lowes. The teflon dries nonsticky and won't attract or hold dust. I was concerned that the lube would cause the plunge lock to not work but no problems so far. As near as I can tell, it plunges as smoothly as the DW621's I've played with in stores.
HTH
Curt
Keith Newton
>I like the teflon lube also.
Every so often, I take the motor off of the base to empty the dust which makes it down around the rods and into the springs. I blow everything out with air. You might be surprised how much dust can get in there.
Besides the dust, feel of the rods for burrs or dings, and sand or file those off, and maybe use some 600 wet-dry paper or finer to give them a light smoothing before the spray.
When you re-assemble, if this one is like the Makita, and Ryobi, you need to be careful as you slide the motor back down over the rods to keep the springs centered, to keep from getting a little binding. Sometimes it takes a couple of tries to get it back on straight. Be sure to spray the springs also.
Do not use grease
>Use ONLY a drying lubricant such as Starett M1 or LPS-1
THat is what a tool repair place told me to do (at the manufacturer's direction) 12 or so years ago.
