Where Hardwood Lumber Comes From-9D The End drying
Bill Tindall, E.TN
>Part 9D Kiln Drying The predryer can do its job with out heating the air, but getting lumber to a marketable moisture content of 7% requires heating the air well above ambient conditions. While the predryer can be a relatively crude affair, kilns are by comparison sophisticated buildings and greatly more expensive to build and operate. This picture shows kilns of 200,000 bdft capacity. Every kiln I have ever seen looks just like these; they vary only in width. They are always silver, I suppose to reflect heat back into the interior and well insulated. In the front they will have large sliding doors to accommodate fork lifts full of lumber stacks. These kilns are heated by steam generated by burning wood waste from the saw mill. Operating costs for these kilns many be only a few dollars per 1000 bdft of lumber dried. Smaller kilns often are heated and dehumidified with a heat pump arrangement. Needless to say, an all electrical energy source results in higher operating costs.
To avoid drying defects water removal must be uniform within the stacks and the rate of removal matched to the species and thickness of lumber that is drying. These criteria are accomplished by fans and baffles that direct air uniformly though the carefully arranged stacks of lumber. There is a hurricane of air moving inside an operating kiln and a constant hum from the fans. By controlling the temperature and humidity of this air the drying rate is controlled so that moisture gradients that would induce stress in the lumber are minimized.
While it is common for the kiln to be charged with air dried or predryer dried lumber this particular kiln dries lumber right from the saw. It takes about a month to dry green 4/4 oak in this kiln while 4/4 poplar can be dried in a week or less. Kiln drying times are shorter if the lumber is predried because it starts out drier to begin with.
It is common practice to dry to a moisture content of 5% and then steam the lumber back to the industry standard of 7%. The post drying steaming relaxes any drying stress induced in the initial drying process.
It should be clear that loading and operating a kiln is a job for a highly skilled and experience kiln operator. Tens of thousands of dollars of lumber are at risk in the kiln. I am tempted to say, � do not try this at home�. But in fact one can dry lumber successfully at home if one understands the principals involved and accommodates these principals in the drying strategy. I have successfully dried thousands of bdft of lumber with relatively crude arrangements. It is beyond the scope of this article to describe in detail how to successfully dry lumber at home but most of the important principals have been mentioned, especially in the Predryer Section.
Well, this is the end. All of these installments have the same boiler plate title so they may be readily searched in the posted Archives. If I remember correctly there are ten parts, with Part 10 having been posted some time earlier. The staff at Wood Central now has the huge task of assembling these installments, with substantial editing, into a final Article for the Articles section.
I would like to credit the following companies for help assembling this material- Banish and Rickard, Gilbert Hardwood, Hunterville Hardwoods, , Linda Hughes Lumber, Malone Logs and Lumber, Mountain City Hardwood, and Stuart Lumber. The people at these companies have been most generous of their time and patience in letting me take pictures of their operations. In addition there were a host of people that offered editing suggestions, most notably Richard Jones. However, let me hasten to add that any lack of clarity, and problems in grammar and spelling are the result of the author�s shortcoming and not the editorial help.
Re: Where Hardwood Lumber Comes From-9D The End drying
Thank you, Bill,
Bruce, a MN galoot
>This has been an extraordinary series, that has really opened my eyes to how wood gets to my shop. I have a new appreciation for the work and technology this whole process takes.
the other Bruce in MN.
Thanks a million
Larry Marker in Alabama
>This has been an enjoyable series to read and very informative. Thank you for taking the time to gather the data, take the pictures, and write it all down in a very clear and informative way.
Job well done and much appreciated!
Larry
Thanks, Bill, wholeheartedly!
Ron Hildreth
>Bill,
This has been a super great series that you've presented, and a lot of hard work that I, for one, really appreciate. When my father-in-law was alive, he would talk for hours to me about the logging industry, but there was always some questions that I was never able to ask him before his death, or he just didn't know. You have helped close most of the gaps, and made me, like Bruce, appreciate where my lumber has come from and given me an insight and reverence that I don't think I fully had before! Again, thank you so much!
As a side note- a fellow woodworker and I had a conversation the other night about home drying lumber. I told him he needed to get on-line and come to WC, and read your series about the lumber process. He hates computers, but I think he might be interested enough to read it for himself, and hopefully become interested in WC. We'll see what happens!
Ron in Iowa
This series will be a mega-article soon
>Bill, we're all grateful for your in-depth reporting on the path from log to lumber. As you know, our articles team is making separate chapters from each of your previous posts and linking them together into one big article so that people won't have to search the messageboard archives to find the pieces.
Thanks again for the great work!
Thanks Bill !
Don Orr
>Excellent series of articles. Well done and very interesting and informative. I read them all with great anticipation. Made my day when a new part showed up !
