Coping Acute Angles
Coping Acute Angles
Coping Acute Angles
Jason
>I've got an inside corner of 44 degrees. My first piece of crown is up, but how do I get the profile cut necessary (on an acute wall corner) so I can see what needs to be coped? My miter blade only swings from +45 to -45. And it would appear to me that my initial cope cut should be closer to 2-5 degrees.
Re: Coping Acute Angles
DB
>It does not matter what the actual inside angle is when you cope a joint. It is all done the same way. The first piece of trim is put up with square ends. On the second piece cut a miter so that the point is on the back side of your trim and you can see the profile on the cut. Take your coping saw and make a cut along the line made by the cut and the face of your trim. I like to undercut this a little to get a nice tight fit.
I hope I made this clear enough to understand. It would be a lot easier to describe with pictures but I do not have any to use.
Keith Newton
>No, If the corner is 44� then each piece of trim would miter at 22�. So if you already have one up, you should miter the other 22� then cope it.
However, I think I would have just mitered both of them under these circumstances. But since you said yo already have one side up, you may need to clamp a block of wood or something to your saw, so your trim comes into the saw 90� from normal, while swinging the blade over 22� from 90. Your cope only has to be 23� or so from the face of the trim now.
