Trying to achieve this look
lee beeden
>I have absolutely no experience with staining, just to let you know.
Anyway I just built a couple of medicine cabinets in Birch and would love to recreate the finish below.
Please note that this is not my cabinet pictured here.
Any suggestions how I could recreate something like this with Birch?
Thanks
Lee
Re: Trying to achieve this look
you picked a tough one
Bill Tindall, E.TN
>I think birch is the hardest wood I have messed with to stain uniformly. The grain typically runs all directions and where ever there is a grain reversal the stain takes darker. Whatever you try, practice on some scrap pieces till you get it right.
Given that I have never stained birch to my satisfaction the following advice should be taken as a place one could start with no guarantee.
Use a gel stain. It may help to precoat with a stain conditioner. I make my own by mixing some linseed oil with mineral spirits, maybe about a 10% solution.
Joe Burke
>This is one of those times when we'd like for finishing to be less involved that it really is. There are so many variables.
As Bill said, the most important thing is to practice on a lot of scrap before you try anything on your cabinets.
The photograph shows something that I'd bet has been stained with an NGR stain (non grain raisng) which dries so fast it almost has to be sprayed, and then toned. Toner being pigmented finish. The NGR stain also yeilds a more even color.
I'd try what Bill suggested with maybe one change. I've had good luck using a washcoat of thinned shellac to even out the color and control absorbtion. You can get Sealcoat, a Zinsser product at most big box stores, which is a shellac product. Thin it at least 50/50, or more, with dentaured alcohol and brush or wipe a coat onto the wood. After it's dry, scuff sand it to smooth the raised grain and then apply your stain.
I also like gel stains, but you could try anything.
The photo shows something pretty dark, and coming close to that while getting even color will be the challenge. If one coat isn't dark enough, apply a thinner coat of the Sealcoat and then stain again.
Now, some gel stains, like Bartley's, contain some urethane so that they can be used as a stand alone finish. If you used one of those, I don't think you'd need to washcoat between stain applications. However, if your stain is only a stain, you'll need the washcoat to keep the second coat of stain from reactivating the first coat. If the second coat reactivates the first you wind up moving around one thick layer of stain as opposed to darkening with two layers.
See what I mean about this being invloved?
After you're happy with the color you can leave it if you've used something like Bartley's. Or you can apply a topcoat over the Bartley's. Or you might need to seal the stain in with another washcoat and then topcoat,
Simple right?
FWIW .... If I had to do this I'd washcoat it and then shoot it with some NGR. Then tone and topcoat. But I have a finishing room full of spray equipment and industrial coatings.
You can get there with the Sealcoat and gel stain too. It's just a different process.
>Hello Lee,
The application of potassium dichromate may be what you are looking for. I always use it on birch. IT IS TOXIC. But it will oxydize birth very well and with uniformity without hiding the grain. Otherwise, I would use an aniline dye, shellac, and perhaps a surface stain to sneak up on and achieve a match/
George
>Lee,
This is an example of solid birch and potassium dichromate. These are finished in a semi-gloss over shellac, and there was no surface stain applied. A little additional work prior to top coating could well yield your desired results.
George
Re: Question Colonel
Larry Clinton
>Those pieces look great (Grandchildren do too). Say - what is the process involved in the potassium dichromate treatment? What is the solution cut with and how much cut? Also what is the cleaning / neutralizing process? My son & I just finished a birch plywood & White Oak light cabinet for a large fish tank last week. I just sprayed the unit with Minwax oil stain - using a HVLP conversion gun set with minimal finish coming out. It did ok - didn't notice any blotching as you can control the amount laid on the surface pretty well that way. Always looking for a better way though, and your's looks darn good.
>Good Morning Larry,
I've used the stuff experimentally for several years, and a little goes a long way. What I say is going to be subjective, since I almost never make notes on mixology. The surface preparation requires you to raise the grain with water and knock it down by light sanding after the surface dries. I drop a fraction of a teaspoon of potassium dichromate powder into a pint of warm water, cover and shake so it becomes thoroughly dissolved. On a scrap piece of stock, I use a bristle paint brush and apply the chemical and wait till it dries. Scuff the nibs as necessary, and hit with spray shellac to find out if I have the desired color and shade. I've never sprayed it, and owing to the toxicity of the chemical, I think I never will try that. I wear gloves and respitator, or apply it outside as precautions. Maybe that it overkill, but I take the warnijngs seriously. Thus far, no problems. If my initial reesult is too weak, I reapply with another coat If too dark, I add more water. The stuff acts dramatically on cherry: a little goes a long way. On birch. you get beautiful results. You can add further color and shade as necessary. Sorry I can't be more specific about the powder/water ratio.
George
Thank you to all that responded!!!!
lee beeden
Geary from NJ
>Hey colonel,,,,,This may seem like a dumb question,BUT where would someone pick up a batch of this potassium dichromate? I wanna try your method on a new sideboard,of white oak and birch plywood,I just finished(well almost finished). I would like to try my luck using your method, with a water base,Minwax "ebony" stain. A major contrast,between the black stain,and my 5/4 mahogany top,is the desired outcome. Maybe I'll use it on the mahogany too? Do you have any thoughts on my "stab in the dark"? Geary from NJ
>Good Morning Geary,
I had to go find my supply to determine the source. Its been a couple years since I bought it. It came from Garrett Wade Company, New York, NY 10013. I seem to recall paying around 10-15 bucks for a packet containing 8.8 oz. The Potassium Dichromate is also known as Bichromate of Potash. Methinks you may also be able to find it via the internet. It works very well on Mahogany and Oak, although I've never used it on oak personally. The mahogany tones out richly.I got inspired when I saw Dave Marks use it on a couple of his shows.
It is certainly worth trying on your project. Use scrap first, or the undersides/insides of the piece before committing. Believe me, a little goes a long way.
George
Re: Thanks Colonel!
Larry Clinton
>I will definitely get some and try it out - especially on Birch plywood. I use quite a lot of the cheap Borg Birch ply for odd projects (like a cabinet for a fish tank light we just completed). Always keep a sheet or two of 3/4 on hand. It is real difficult to get an even stain on it. Spraying is ok in the summer, but tough in Winter. I have a large shop so fumes aren't normally a problem. When they do become strong I just pop the overhead door open for a few minutes - even in winter. Been saying I am going to make a collapsible spray booth but it's one of those Round tuit it projects that may never happen. Thanks for the answer.
