Pin Router
woodie1
>Does anyone have or know of any plands for a Pin Router?
Pin Router
woodie1
No, but I'm curious...
>...as to what types of work you plan to do with your pin router. There are many sizes and styles out there, for everything from light-duty pattern routing to heavy-duty shaping and floating head applications. I'm assuming that if you want to make one, it will be of the smaller, more modest variety, probably with an overhead pin. All I can say is that the engineering of the arm and the pin need to be very rigid and very accurately aligned with the router bit. That's no small feat, especially if you're thinking of making this table with mostly wooden components. Lee Valley sells a pin router attachment for their steel router table. This is probably the sturdiest, most accurate inverted pin router design you'll find at an affordable cost. If I'm not mistaken, Woodhaven also has a kit you can buy.
If you're ambitious and think you might want to use your pin router for shaping and production operations, with larger cutters, I'd say look for a used Ekstrom Carlson or Onsrud or Porter pin router. Those old battle axes never die and they are just as capable of fine work as big stuff. I'll bet you can find one for under 1K these days, as CNC machines have largely taken the place of pin routers in industry. Don't count on finding one with a single-phase motor, but don't hesitate to run it off a static converter. They work just fine.
Ellis Walentine, Host
Re: Pin Router
woodie1
>Found this if anyones interrested http://www.popularmechanics.com/home_journal/workshop/1274466.html
