Re: Shellac
Glenn Madsen near San Francisco
>I'm not Bill, but I'm a shellac convert. Amen!
For a beginner, go to the hardware store, and get some Zinnser SealCoat, and a can of Denatured Alcohol. In other countries, it's often called something else, but it's the solvent for shellac. Put the Sealcoat in a squeeze bottle, and add maybe 50% of that volume of DNA, and shake well. Now squirt that on a lint-free old tshirt scrap, and wipe it on a scrap piece, gently. It dries in about three minutes, and you can do it again. You can wipe on maybe three coats, before you need to let it cure for several hours, or overnight. Repeat this until the finsh seems good to you, and rub it with burlap, steel wool or white synthetic abrasive pad, dipped in paste wax. Let that dry, and rub it with a clean soft cloth until it glows. It's really hard to screw up.
Now do your project, with confidence.
You can mix your own from flake, and use different colors, dyes, and the like. But to start, Sealcoat works really well, and you don't have to buy three years supply to get started.
