Planer questions
Nathan
>I was planing some 1" x 6" pine stock and encountered some sticking and snipe. Two questions for the more experienced planer operators out there:
1. Does high sap content in a pine board make it more likely to stall in the planer? I waxed the planer table and cleaned the rollers prior to running this stock. Still, some of the boards would stick like crazy. Two boards in particular were major culprits. They seemed to be denser than the others, and stickier to the touch. How to prevent this? Like I mentioned above, I applied wax (the liquid floor kind) to the table prior to running the boards, so I was suprised by how much they stuck.
2. I got snipe on the ends of many of the boards. I had not jointed the boards prior to planing, so I suppose some of them could have been slightly bowed, but all in all they are quite straight and flat (these are offcuts of T&G floorboards that I was planing down to use as stickers). I hadn't had a snipe problem on the planer before, so I'm at a loss how to explain this. What to look for as a cause?
The pine I'm planing has a moisture content of 11%. Is this too high? I made a big batch of stickers before by resawing from 8/4 stock with a moisture content of 9%. They were 2" wide and planed just fine, though I was taking lighter cuts. This problematic stock is 6" wide and I was taking off 2mm (a little over 1/16") at a time.
Any comments appreciated. I wish I could get to the bottom of this.
Nathan
