Sand shellac barrier coat?
Tony Sade (Charleston, WV)
>I sprayed a couple of coats of shellac over an oil-based gel stain to use as a barrier before I put down a couple of coats of a water-based poly. Is there any need to sand/abrade the shellac first or can I just spray the poly right on top of the untouched shellac? The shellac will be on for at least 24-48 hours before I'll have time to get to the final finish.
Thanks,
Tony
Re: Sand shellac barrier coat?
Nope
Michael Dresdner
>You don't have to sand it for adhesion. Sand only if it is not smooth and you need to smooth it before the next coat.
