Stacking dust collectors?
Gary Evans Tallassee, TN
>Hi all,
I'm still working on the design for my DC system, but basically, I will have a single run of 6" diameter PVC pipe, 33' long, in the basement of my shop, into which I will drop 6" pipes from a lathe on one end, then a radial arm saw, band saw, belt/disc sander, 12" CMS, 6" jointer, 12" planer and then a 10"table saw at the end where the DC will sit. Location of the DC is next to the outside basement wall where I can blow the dust outside.
Turns out I have a 1HP Craftsman DC in addition to the 2HP generic 2 bag DC that I am using as the basis for this system.
I'm wondering if I can put the Craftsman in line at the end of the 33' duct and then run that straight through the 2HP unit to the outside.
Anybody know of the negative/positives of stacking one DC in front of the other?
Thanks,
Gary
Re: Stacking dust collectors?
I seem to recall someone from the old badger Pond
Don Henthorn Kyle, Texas
>tryong this and he found that it did indeed increase performance. Probably there are others who will remember more clearly. I am presently suffering from CRS and don't trust myself.
Re: Noise?
>Noise might be one negative.
John Dillbeck
>You are right and it was Jim Halbert. He ran exhaustive test on two blowers and found that a series hookup was best. I have seen his setup and he has both units outside.I don't remember the cfm numbers but he had two 2hp units with 13in impellers.
Re: Stacked dust collectors!
>Did he also have hand grips and safety lines?
How about mag-lok shoes?
Wouldn't it be easier to just build a shop in a wind tunnel? Like, no ductwork to worry about, a couple of ear plugs, and a safety net to catch s---- before it hit the fan, and you're cool. No?
[I do remember Jim from the Pond. How's he doin']
Re: Noise?
>Hi Jerome,
Both of these will be in the basement, so noise is not as much of a consideration. It seems like this might be a good way to go, but I thought I would ask before I spent the time and money to hook it up that way.
Gary
>Thanks Jim,
That is one of my concerns. One of my units has somewhat less flow than the other, but I thought I might negate that by putting the small one closer to the tools.
Gary
>Hey Mark,
According to everything I'm reading, max airflow is the ticket. I'm just trying to figure out how to generate that with the least possible investment.
Gary
Air
>Hi Gary,
You are correct; it's CFM that gets the dust moved. Of course hurricanes work on the same principal |;-}}}.
I just re-did my system with 6" ducting, resetting my old 2hp blower, and putting on a 6 foot filter bag. Easily doubled (if not tripled) the CFM.
Moves so much air, now I'm getting complaints about the noise.
Before, I got complaints about the dust.
Can't possibly win.
But at least the shop is clean. |;-}
mm
