OT - Norton Internet security problems
Denis Ch�nard, Orl�ans, Ont.
>Since running the latest Live Update, the Windows machines on our network can't see each other anymore. Internet access and printing are not affected.
Looking under the hood, I found out that Windows Firewall got somewhat re-activated, turned that off, no change. Played with the firewall settings to the best of my (limited) knowledge, no success. Ran the Network setup wizard in the Control Panel, still nothing. Re-booted the machine, got a popup message from Norton saying that Windows Firewall was on, turned it off again. Turned off Norton Firewall temporarily, still nothing.
The problem seems to be the same on all the Windows machines. Linux machines on the network seem as accessible as before.
Any ideas? All the Windows machines run XP Pro.
TIA,
DC
Re: OT - Norton Internet security problems
Suggestion
Dan Donaldson
>Dump Norton. It is intrusive and a resource hog. There are others out there that are less offensive and a lot less expensive. Unfortunately, Norton is very difficult to get rid of. Part of the reason that I don't like it.
Rod Peterson -- Ormond Beach
>After all of the discussions in the last six months on anti-virus software, firewall software, and the resources hog that is Norton, why are you still fighting with it?
AVG (free) and Zone Alarm (free or cheap enough) are both easily accessible, easily run, and Norton is easily (and rightly) dispatched.
I got them a few months ago and feel pretty good about it. I don't have any particular anecdotal tales to relate, however.
Rod
Dan and Rod, completely agree
>Norton is a POC software, a hog, and anything else bad you can throw at it. Unfortunately, it's been chosen as the standard protection software at the office, so I can't get rid of it. Now that I'm taking over the management of our outfit, things will change in the future, but for now I'm stuck with it...
DC
Running Linux (Ubuntu) here at home
Re: Dan and Rod, completely agree
Dan Donaldson
>How long have you been on ubuntu? I have been running it since April and my last two computers were specifically chosen for compatibility. So far, so good. Gutsy is running great.
Zone alarm & Avg Only way to go
del schisler
>have use these for over 1yr or so work's very good And free Also CCleaner is another good pro gram And free
Re: Zone alarm & Avg Only way to go
Rob Stokes in North Vancouver
>I've been a Zone alarm fan for years, but it's proven to act strangely when I set up the home network. Sometimes it let the "other computer" print via the main one and other times it wouldn't even allow files to be shared. I think the issues had more to do with updates - where an update seemed to wipe out some configuration, but never cleanly.
Bottom line was my kids couldn't print their homework and I ended up spending hours and hours trying to sort it out, time and time again.
When I removed Zone alarm from both PC's and fired up the stock Windows firewall instead, everything came up and ran.
So for a single PC - Zone alarm is fine but for networked PC's, I'd not use it.
Rob
>Been on it for a month or two now, compared to the old distros of a few years ago it's degrees of magnitude better, yet there are still rough edges here and there. I had to reinstall Feisty after upgrading to Gutsy because VMware was not functioning properly, and I still need a Windows implementation for various tasks. But I'll get there at some point...
The thing is, I don't want to have to go deep under the hood to make things work (any OS), that ends up being a "time black hole".
One thing is sure, I'm not migrating to Vista...
DC
Dan Donaldson
>I have an xp implementation in virtualbox that seems to work fine. I originally installed it in fiesty, then after Gutsy came along, I copied the virtual file over to the new Gutsy install, installed virtual box, and loaded the same xp install there. It all worked and all of the applications were still functional. I then copied the same file over to a different computer with Gutsy on it and it runs there also. I only boot it up once in awhile just to see if it still works. ;-) Haven't actually used it for months.
The next ubuntu release is going to be an LTS version, so I am going to imagine that they will be working toward stability and ease of use rather than any "new" features. That version may be the one that you need for the stability. So far, I have been able to get everything I need either in replacement software or under Wine, so am happy. I do like to tinker, though, so I do break stuff sometimes, but have gotten fairly good at recovering from my mistakes ;-)
Question
Dan Donaldson
>Were you using the free version or the paid one? The paid version has some features missing in the free one, especially related to multiple PC's and NAT stuff.
Re: Question
>I was using the free version.
Funny thing about the whole mess is that everything was working well for the longest time. And then it wasn't. When I went back over what had occurred, the only thing was a Zone Alarm update. That's not to say I couldn't get ZA to work again, I imagine that had I persisted eventually the actual problem would have been found. But I gave up in (massive) frustration.
Rob
Re: Question
Dan Donaldson
>Just wondered. I used it for a long time when I was running Windows, but I had the paid one. (I originally got it when I needed the NAT capabilities) Eventually, I had problems with it and changed over to the comodo firewall.
Larry Clinton
>Have to agree, I had AVG & Zone alarm (free version) installed -running XP pro and wired network. I ran into problems with my network & email. It would refuse to allow Outlook Express to open. I could go though Zone Alarm settings and make it allow the email, but the next time it opened the same problem occurred. I already had a router firewall so ended up removing ZA. No more problems. I have since changed to a wired / wireless network but won't mess with Zone Alarm due to the problems I had.
