Performax Speed
Doug Reynolds in Seattle
>I am using my Performax 16-32 to do some "Jointing/planeing" of boards too wide for my 6" jointer, especially following panel glue-ups. This is not rough wood from the mill but, more like S2S. Taking real light cuts with 120 grit, what is the most desirable feed belt speed? Is burning, on cherry for example, more likely at slow speeds?
I would think a slower speed would result in greater consistency of thickness and better overall quality but, I think the manual says to run at highest speed possible.
Once I have the boards flat, what is the best way to remove the sanding marks which tend to be pretty deep? Random orbit sander does not work very quickly. But, I do like the flatness of the panels over the results I might get with a belt sander.
