OT - Electrical - 2 problems - HELP!
David C. Lykins - guitardude - Dallas GA
>Problem #1 My hot water heater has two elements, the top element receptacle has the thermostat AND a circuit breaker (built in). It's been blowing the circuit breaker (In the water heater) once or twice a week. I now have both thermostats turn down as low as they can go and the circuit breaker is still popping every other day or so. The heater is about two years old, its a "STATE" water heater, I'm assuming the breaker within the water heater could be faulty?
Problem #2 Got a friend that has a couple of outlets and switchable ceiling lamps quit while vaccuuming. They had this happen once before and flipped the breaker at the box and everything came back to normal. Now only the outlet that the TV is plugged into is working and the others are not. I've check EVERY circuit breaker AND Ground Fault outlet in the entire townhouse but still can't find the problem. My gut feeling is that the surge may have made a connection seperate somewhere in an outlet box or junction box somewhere. Looking for ideas as to how to trouble shoot this further.
Any help is greatly appreciated.
Re: OT - Electrical - 2 problems - HELP!
Kneale Brownson awaiting snow in N. MI
>I'd expect you have a bad breaker on the water heater. If you had an element short, it'd be shorted all the time.
I'd examine the wiring on the lighting fixtures. They frequently have very limited wiring in them. If all seems OK, look into the outlet boxes.
Lee Schierer - McKean, PA
>I suspect the element may be going bad and it shorts out periodically, thus tripping the breaker. They are not hard to replace, but you will need to drain the tank at least below the upper element.
I would suspect that you have a loose connection in the outlet where the TV is plugged in or the very next one in the string. Most home outlets are daisy chained one to the next. If several outlets downstream are off, that means that there is an open circuit in the link. Turn off the power and check the connections in the TV outlet. There will most likely be four wires connected to the outlet. One of them may be loose. If not check the next one in the line. The next closest outlet to the one that is working is most likely the next one in the string.
You may also find some burned screws or wiring. Replace an/or remove any wiring or outlets that have burn marks.
Lee
Problem #2
David Yoho
>For your second problem, I've seen this happen when the neutral wire came loose from a receptacle where it's plugged into the back. Look for a loose or disconnected neutral. Personally, I like connecting wires to receptacles and switches by putting them under the screws.
David
KILL THAT CIRCUIT
>Before you go further, and, as Lee and David have said, pull every receptical in the line to check for and/or remake proper connections. If the original sparky used the speed-wire port terminals, release them, rewire to the screw terminals with proper loops, and replace any devises that show any wear, or cracks.
What you have described is, very likely, a fire waiting to happen. The electrical fairies have given you a warning; don't ignore it. Probably wouldn't be a very bad idea to check the other circuits and outlets for loose wires (with the respective breakers turned OFF of course).
MM
jmohnike
>Check the wireing especially the ground on the unit and breaker box.
Also shut off the water, and disconnect both water lines at the tank, look inside the flex connector and see if the unit has been trying to ground itself by looking for a arc or electrical burn. My neighbor had the same problem, had to pull a new 220 line and replace the flex lines.
good luck
Joe
>I agree with all of the above.
If the outlets are "back stabbed", undo them and connect hem tot he screws. You did not say how old the unit is, but if it has aluminum wires in the 120 volt branch circuits, be extremely careful. (late 60's early 70's). Be sure the devices are rated for aluminum wire.
If you drain the water heater, the FIRST thing you do is turn the power off. The LAST thing you do is turn it back on, after you run some water and get all the air out. Use the bath tub to avoid clogging your aerators with crud you might shake loose.
