200+ woodworking book reviews
Math wizards...help
Math wizards...help
Math wizards...help
DocJim...Fayetteville, NY
>Ground rise (46") over run (175") = ? angle
Re: Math wizards...help
Mike Baker
>Answer
14 degrees 47 minutes.
Lee Grindinger
Sheesh
Lee Grindinger
>Cripes, 14 minutes for the answer?
Lee
Re: Too Fast?
>After all, he did leave out the "seconds" calculation.
Don Pierson
>Google the string 60*arctan(46/176)
The reply is 60 * arctan(46 / 176) = 15.3386955
Since you said ground rise......
Basil
>.....you must be doing some grade work and as such that would be a 26.3%(percent)slope or roughly a 4&1/2 to 1 slope.
OOOOPS..........
Basil
>That'd be a 26.3% grade or roughly a " 3 1/2 to 1 slope ".
But why the discrepancies?
doug f, san clemente, ca
>All right, you math whizzes (whizii?). There's several different answers here. The angle is about 15*, no question, but why are there at least three different numbers? I fired up Turbo Cad and got yet a slightly different answer.
Inquiring minds want to know..., or not.
Doug
Re: But why the discrepancies?
Dan Donaldson
>Possibly depends on how you enter the numbers and what the precision is for the calculation method. I did it on my calculator, in excel, and in the Google calculator and all came up with 15.2397 degrees rounded to 4 places.
I did it by using arcsin(46/175). In Google and Excel, I multiplied the result by 180/pi because their answers were in Radians.
Picking nits here
Tim Greif - West of Chicago
>Dan, the OP stated rise and run. If you used the Sin function, you're calculating wih rise and hypotenuse. Rise and run uses a Tan function. I get 14.7274 as the arctan of 46/175.
Re: Picking nits here
Mark Serfas
>Tim is correct. The original question stated rise and run, which are in mathmatical terms the opposite and adjacent sides of the angle in question. How were these numbers for rise and run measured? If they are truly rise/run, then Tim's answer is correct using the arctan function.
arctan(46/175)=14.7274 degrees
arcsin(46/175)=15.2397 degrees
OOps
Dan Donaldson
>You are right. CRS moment ;-)
Yes.....
>Yes, if the ground is rising that much, then run.......
Happy Woodworking!
I really appreciate a good sense of humor.
Art Silva
Mike Baker
>Rise over run is the Tangent function. My answer is the correct one.
RISE OVER RUN IS THE TANGENT FUNCTION>
46 divided by 175= .2628
That is the TANGENT equivelent to 14.72 degrees.
Now that is DECIMAL DEGREES
therefore you multiply .72 times 60=====
43.2,,
and ifs yas wants to get down and dirty then multiply .2 times 60====== 12 therefore the angle==
14 degrees, 43 minutes, 12 seconds.
Mike
Rise over run is the TANGENT function
I am with Mike, only off the top of my head,
Keith Newton
>Here is how I would figure this.
A circle with 57 5/15, has a cir of 360, thus one inch along the arc = one degree.
So three time 57.39 ? 172, or pretty close to the 176" of run, so three into the 46, is going to be 15.3.
It took me about 15 seconds to figure that it was just under 15 using this trick.
Once you get the hang of using this formula, it gets easier with practice.
If you have a good memory for numbers, here are some other factors of this. divide the 57.395, by 2, then you use 28 5/8 for the radius, and each 1/2" along the arc will = 1�
Or 14 5/16, each 1/4 ? 1�
or 7 5/32, each 1/8 ? 1�
then finally when you are down to about a 2x4 width, or 3.5" ~ 1/16" out of square is ? to 1�
give a man a fish...
JohnKJordan in East TN
>It's helpful not only to know the answer, but how to figure out variations of such problems in the future (as in, "give a man a fish... :).
Draw a right triangle with one point to the left and the 90 deg corner on the right, such that the right side is vertial and the "bottom" is horizontal. (Little picture attached.) The third side of the triangle, the longest side, will slope up hill to the right. The vertical side of the triangle is the "opposite" side, the horizontal side is the "adjacent" side, and the sloped side is the "hypotenuse". (BTW, the terms adjacent and opposite refer to the triangle sides adjacent to the angle and opposite the angle.)
The angle in the forumlas is the angle between the adjacent side and the hypotenuse of the triangle.
To help remember the triangle formulas for sine, cosine, and tangent, there is a simple mnemonic you can use: "oscar had a heap of apples", where the first letter of each word represents the side of the right triangle, i.e.,
...... o=opposite
...... a=adjacent,
...... h=hypotenuse
To remember the formulas, write a fracton with two words of the mnemonic with each function in order, i.e.,
...... sin = oscar / had
...... cos = a / heap
...... tan = of / apples
so,
...... sin(angle) = opposite / hypotenuse
...... cos(angle) = adjacent / hypotenuse
...... tan(angle) = opposite / adjacent
For this problem,
...... vertical height of rise = opposite
...... horizontal length of run = adjacent
...... distance up the hill = hypotenuse
so,
...... tan(angle) = rise / run
Solving for the angle,
...... angle = arctan( rise / run )
If you remember the mnemonic and the order (sin-cos-tan), you can always write down the formulas and figure out a variety of triangle problems.
But, teach a man to fish,...
>and he'll sit in a boat and drink beer all day!
Clint
Re: give a man a fish...
John in Calgary
>You forgot to put in Mark's guy running in your picture.
