Re: MiniMax bandsaws - in WV?
Larry Clinton
>I have the MM-16 - I couldn't be happier with any bandsaw. The saw is built like a tank. Has almost no vibration, you can barely hear it run. It has 4.8 Hp, I haven't slowed it down at all cutting 12" thick white oak. I have a 1/2" woodslicer blade on it right now. It came with 3 blades (my choice of widths) - as they came a couple days after the saw, I haven't tried any out as the Wood Slicer has done everything I needed. The mobility kit is adequate, uses a tow handle, works ok but I do like the other style (lift up wheel). The mobility kit is mounted in such a way that you need to remove a wheel when installing a wide blade (The wheel stops the lower door from opening all the way. Could install a spacer to move the wheels back (some people have), but isn't a big deal as I don't change blades that often. One thing I don't care for is the on / off switch design - seems awkward to me, but it does work ok. I may change it in a few years to a standard AB or Square D type. On the other hand I may get used to it and forget it :~). It has an excellent, extremely heavy duty table and trunnion. My top was very flat (within .003").The tension is very easy to set and the saw has more than adequate rigidity to properly tension the max. (1 1/4" blade). Minimum blade width is 1/4" which will cut any radii I would normally need. Table is flat, fence is heavy duty cast Iron, capable of adjusting for "lead". Dust collection is ok, does gather a little dust in one corner, but doesn't seem to build up after about 1/2" or so. Customer service is excellent. The salesman called me after I received the saw to make sure everything was ok, then called about 6 month later to check in again and insure I was satisfied. I haven't seen the lighter duty saw (E 16), but the specs indicate it is a whole different unit. It is much lighter (320 lb VS 530 for the MM 16)saw. It also has less resaw capacity 12" VS 16", a smaller table and a lot less horsepower (2.5 VS 4.8). I don't believe it is even made in the same factory so I can't comment on the quality. I looked at the Laguna, Minimax and several other (larger) saws before I purchased my MM16. I would buy another one in a heartbeat, don't think there is a better saw on the market for anywhere near the price.
