OT Open end wrenches
Tom Norton
>Is there such a tool as a "thinner" open end wrench? I need to adjust my planer and it has a jam nut and both wrenches are 5/8" but the bottom nut requires a thinner wrench.
Tom Norton
Re: OT Open end wrenches
Dick Heineman
>I went through the same thing a few years ago and ended up grinding one down to the right thickness on my bench grinder.
Re: Yes, check out your LBS
Kris Lasure
>Hi Tom -
A stop by the local bicycle shop (LBS) should take of your needs. Wrenches for bicycles are just plate steel around 1/16" thick. Being a cyclist myself, I use my wrenches every once and a while to adjust tools in the shop that require that certain thickness to reach into tight areas. You mentioned 5/8" which is equilavent to 15.875 mm. Most bicycle tools are metric so grab a 16 mm wrench and that should do the trick.
- Kris
Yes, Tappet wrenches
Bill Hammond, Oregon Coast
>Tappet (sp?) wrenches used to adjust the valve clearance on a camshaft. Sears and auto parts stores sell them.
My Sears wrenches are slightly more than 3/16 while a normal wrench is 5/16 thick.
If you grind down a full size wrench be careful not to loose the temper.
HTH
Bill, on the sunny Oregon coast
Sears used to make full sets
Ray Thompson - Middletown,IN
>called thin wrenches.
Ray
Re: Superthins
Kneale Brownson awaiting snow in N. MI
>Tool Warehouse lists an SAE set for around $18 HERE.
Re: Superthins...whoops
>Try THIS
custom made required for me
Bill Tindall, E.TN
>I bought a thin wrench and it was too weak to unstuck my jam nuts. So I ground, carefully without heating, a regular wrench until it just fit the slot and that worked.
