>I'm looking at buying a tenoning jig for my PM2000 & this Woodcraft is on sale, $20 off. At least I'm assuming it's Woodcraft brand, no indications to the contrary & it's "their color". Anyone have experience with this, or any other suggestions?
>I bought this tennoning jig and like it except I found it to be a little slopply in the miter track. You are supposed to be able to adjust this but I could not get a tight fit.
It's worth noting that the WC jig is identical to several others with different color paint jobs, so be alert for the same tendencies from them too. Otherwise it's a very nice jig.
Mine has a plain steel bar that should fit into the groove on the table. It fits my saw well enough. If yours has a little slop, you can peen it at both ends and then file it to fit exactly, even if it does not have the adjusters. The gremlins that use my shop when I am not there knocked my tenon jig WAY out of alignment. Took a while to find all the anchoring screws. The left sub base had to be way over to the right and the right superstructure had to be over to the left and you had to be ambidextrous, if you know what I mean.
I bought a track for making a cross cut sled (or whatever) and it has the adjusters. The track is aluminum. Aluminum and steel are not the best combination. Aluminum galls easily. Took a bit of tweaking and some wax to get things sliding as smoothly as the steel bar.
>I think it is exactly the same as many others, I bought a jig from Rockler when it was on sale - appears to be the same unit. I did have to disassemble mine as some of the bolts were loose and the face of the jig was not parallel to the miter bar. I clamped a dial indicator to the saw table top and passed the jig by it, adjusted until it was parallel. The miter bar does have some slop in the slot (about .002" ~ .003"). I was going to peen it and fit it to the slot, but found it is kind of handy. I set mine so the tenons I cut are tight in the mortise, make my cuts with the jig pressed against the slot so the tenon is as wide as it can be cut. I do both sides this way. If the fit is too tight, I press the jig against the other side of the slot and make another pass on the saw. If its still tight I repeat on the other side of the tenon. Works like a charm for me.
>I have one and and it works great, its the old Delta model, if you look on top you will see to small holes they still drill them as this is where the Delta name plate went. Its the best deal around on a tenoning jig.
>Picked up the jig today. Seems fine, although I had to completely disassemble the unit & clean each part in a pan of mineral spirits with a chip brush to get rid of the anti-rust coating. Man I hate that stuff. On the issue of the miter guide width, it is pretty narrow, but on mine there are 2 allen screws, at the front & at the rear of the bar which allow adjustment. They're not the usual vertical screws operating to expand a split in the bar, they are horizontal through the side of the bar & screwing them in produces small "nub" on the opposite side of the bar which effectively increases its width at that point. Works quite well.
