See my Guide at the Link *LINK*
Garrett in Victoria
>I recently posted an installation guide - see link below - for the MastRlift (the Rockler is the same unit in blue rather than red) that also includes comments on the other routers that will fit it.
The two big ones - 15 amps - are the Porter Cable 7518 and 7519 which just drop in as is, and the Milwaukee 5625 which JessEm seems to show in their promo photos, but which requires a shim kit made by JessEm. The PC 7518 and Milwaukee 5625 have variable speed which is important, the PC 7519 does not.
The smaller PC 690 series and other similar round body routers such as the Bosch can also be used with a JessEm adapter. (My post shows the 690 with adaptor).
However, if you're buying a new router for the lift, it seems to me that the only way to go is the PC 7518, since that's the router the lift was designed to take, and the price differential after you add in the adapters isn't significant over the many years you'll probably use the combo.
Cheers, Garrett
MastRlift & Router Types
