using leftover waterbased poly
DizD
>Had a pint or so in a gallon can last used about a year ago and when opened, it appeared thicker than normal. I understand there are problems with thinning water based poly, but what about thicknening?
Would use this for shop project so appearance is not critical. I recently bartered some log run walnut for two old Delta Rockwell lathes ( circa 1953)and will be putting one together to use. I have cleaned up the wooden bottom shelf and planned on using this for a finish.
