Router in Unisaw extension table on mobile base
Bill H-Evansville, IN
>I would like to install a router in the extension table of my Unisaw on a Delta mobile base. The legs are located in from the corners so it would seem one of them would be right in front of the router. Also, the standard table board has a reinforcement right where the insert should go. It seems that it would be awkward to access the router from the front of the saw past the fence. I'm sure others have done this. Did you just move the reinforcement? Is it troublesome to work around the table legs? Should I just plan to access the router and work from the back of the saw for routing work? Hope you have some advice.
Thanks in advance,
Bill
