Where Hardwood Lumber Comes From- 9C Predryer
Bill Tindall, E.TN
>Part 9 C The Pedryer
This is the next to the last installment. Later in the week I will post the last section on dry kilns.
After stacking (or stickering as it is sometimes called) the stack may be placed outside with a cover over it for air drying. Air drying is cheap and it is what was usually done some years ago. But the drying rate is subject to the weather. With too slow drying of the lumber stacks the lumber may stain and with too fast drying the lumber is subject to a multitude of drying defects. When the stacks dry too fast moisture gradients develop in the individual boards. Because lumber shrinks when it dries any moisture gradient that develops across a board induces stress as a result of differential shrinkage. This stress can split, check, honeycomb, warp and twist the lumber.
In addition, the wetting, drying and sun on an air drying stack out doors will turn the surface of the lumber grey. While this discoloration is of no practical consequence, now days it is important for lumber packs to be attractive even to the point of painting the ends of lumber stacks and putting company logos on the sides. To avoid all these outdoors drying problems some large mills to use predryers.
The function of the predryer is to do what outdoor drying once did, but in a controlled way. The drying rate of the lumber is controlled by controlling air flow through the stacks as well as the humidity of this air. By carefully controlling the drying rate defects are avoided and the lumber stays �bright� and attractive.
Predryers come in many variations of sophistication. This predryer is a pole building with fans to move the air through the stacks and side vents that are opened or closed to control humidity, which in conjunction with the fans, determines drying rate. Predryers can hold as much as a million bdft of lumber.
