Waterbase finish question
Jeff Weaver
>I have a small box project coming up where I will use either maple or holly, and I want to keep the "white" look to the wood as much as I can without the ambering associated with oil-based varnishes. From what I have read so far, water-based poly should be my choice for a truly clear finish. My problem is brushing on finishes. The quality of my finishes went way up when I switched to wipe-on varnishes and oil/varnish mixtures. I'm just a lousy "painter," and always had brush marks, runs and drips with brush-on poly. So my question is this, can I use water-based poly as a wipe-on? What I have available locally (Lowes/Home Depot) are Minwax Polycrylic and Olympic waterbased. From reading the cans, they don't recommend thinning with water. Can they be used as a wipe-on straight from the can? Any preferences among these? Other suggestions?
Thanks in advance.
Jeff Weaver
