Bandsaw fence question?
>I have a Delta 14" bandsaw with riser. I don't have a fence. I do have the fence off my Delta?Rockwell Table saw. (Saved It when I upgraded the fence)
It occurred to me that I could mount that fence on the band saw. Either just put a front pipe rail on the BS and let the far end of the fence "run wild" or cut the fence off and shorten it so the far end would clamp to a rail on the other side. I think there is enough "adjustment" in the fence to allow for drift. Does this sound like a good idea or should I skip it and keep the TS fence in case I decide to sell the TS and keep the upgrade fence?
PS, Does a BS fence need to lift off? This one slides on from the ends. What fence do you have? What would you get?
