200+ woodworking book reviews
Fiberglass Front Door
Dick Krieger
>After building my home in 1998, my wife finally convinced me to stain/finish the front fiberglass faux wood grain door. Instructions said to use a gel-stain. Bought a MinWax product and started. Desired color is somewhat equal to Provincial Oak and trying to get that effect with gel stain was tough and I concluded impossible. Instructions said to use multiple coats after drying time. Still didn't work so I began to exercise my brain alittle. After some thought, I used the same stain we used on the oak trim, put it into my Devilbiss MBC spray gun, turned pressure way down to about 10 psi and sprayed the stain on door. Came out just great. Looks just like wood. AFter stain dried, I put a few coats of satin poly on top and now Momma is happy. Most of you are probably already aware of this possibility, but I thought I would share it. With the spray gun, you can control how much color and "depth" you get, MUCH MORE easily than using gel stain. For what its worth.
Re: Fiberglass Front Door
Don Bullock
>I'm very upset about my fiberglass door. Where the sun hits it in the early morning for just a few minutes it is disintegrating. The white fibeerglass is showing through and actually flaking and coming apart. I hope yours is in a place where it doesn't get any direct sunlight.
