nail on the head
JohnKJordan in East TN
>>I think CAD users have a rougher time of it because
>the mindset of the programming is altogether different
I think you hit the nail on the head. I am a 3D modeling and animation guy (before I retired, anyway) and found SketchUp intuitive and fairly easy to use once I learned what command did what function. Unfortunately, I don't use it enough to be efficient. (Ask a question about 3DS Max and I can probably help, though)
Years ago, I used Autocad extensively and was very fast with it. Today, I still use it occasionally but find it cumbersome and very slow compared to my 3D software, even for 3D work. I think I switched mindsets over the years!
Tony, I don't know what the problem is - I tried starting with a single block and subtracted four simple edges with curves as I illustrated before and it worked OK, except at one point it lost an end surface I had to replace. It sounds like you are creating one intersected object then using it for further intersections? I don't know how SketchUp handles that, but some other packages get confused with multiple booleans. Also, some packages blow up if you have any faces or edges coplaner (sitting exactly on top of and aligned with other faces) - could that be the case?
There are some other good ways too build a complex object, for example by adding several pieces together rather than subtracting several times.
I'm having trouble visualizing your model from your description, perhaps disadvantaged by being unfamiliar with the terms "cabriole" and "knee". Again, I am NOT a SketchUp expert, but I'd be glad to take a look at your object if I can open your file with version 5. If you want that, send an email.
