Re: Need information on Boyce Crane motor pulley
Mike Baker
>I had a Boyce Crane saw that had that same slip pully you described.
I sold that saw to a friend, and it now sits in a garage across the street from me!
I still get the opportunity to hear and see that great old saw run!
Gothemburg is no longer a good place to get parts for those saws. The old man died, and his wife made a valant effort to keep the bussiness going. Last I heard it is no longer.
I am a Machinist by trade, and I took the motor shaft, that has bearing grroves ground in it, and found they were still in pretty decent shape. I took the pully apart, and found the small ball bearings had worn. I polished the bearing grooves on the shaft, using turned pieces of brass that were the correct diameter, and lapping compound. \
I then ordered some new steel ball bearings from McMaster Carr. (I miced the old ones and found the same diameter still available).
I reassembled everything and its still working smooth and quiet today. This all happened over ten years ago.
Im sure you could take the assembly to a machine shop and they could help you out with this.
Good luck
Mike
