Sketchup Question
Sketchup Question
Sketchup Question
Tony - Memphis
>I've been playing with sketchup for a while. I've never liked it because I thought it was so clumsy. I've been spoiled by high dollar CAD systems. Has anybody figured out how to draw a lams tongue on a corner? I can get a plain chamfer ok, but haven't figured out the lamb's tongue yet. The whole philosphy of this application is very different that what I have used before - frustrating! Argghhh!
Thanks,
Tony
Re: Sketchup Question
Mike Schwing from Md.
>I gave up on it after being perfectly able to follow the tutorials. I gave up on it because even after taking all of the tutorials, I could not figure out how to define the dimensions of a simple rectangle.
I wanted to draw a box inside a box, define the outside box, and then have it tell me the dimensions of the inside box. Doesn't sound too complicated, but maybe I was using it for something for which it was not intended. If it was that hard to figure out something so simple (and following the directions did not work), I couldn't imagine it for something more complex.
The tutorials were fun, though.
Ralph Turney
>I was hoping this program would be a good 3D substitute for Autocad...am I wrong? I haven't used it yet, but was going to download it and give it a try soon.
Ralph
describe what you want?
JohnKJordan in East TN
>I've used Sketchup extensively on several projects (in conjunction with other 3D software) and several architects I know (inclding one son) use it daily. It is very good for many architectural things but does not yet match some professional packages on others. It has one of the best relational snap implementations in the industry which makes it very quick to do things that are painful on some other packages.
You said "has anybody figured out how to draw a lams tongue on a corner?" Unfortunately, I'm not familiar with a lams tongue.
What version do you use? I have Sketchup pro 5 and would be glad to look into it if you can describe or show a picture of what you want.
lamb's tongue?
>I found a reference to lamb's tongue and it seemed to be a treatment on the end of a beveled edge. Is that correct? If so, you can do that with Sketchup. I couldn't quite see the detail in the reference I found, so I made a simple curve at the end of a bevel but the same techinique could make any profile.
I used what Sketchup refers to as "intersect with model", a type of operation referred to as booleans in other packages. I created an extruded square for the piece, then created a second piece by drawing the desired profile then extruding. Rotate the extruded profile, intersect, then delete the unused pieces.
BTW, Sketchup's inplemention of boolean is clunkier than most but it still works. Perhaps it is different in a later version, but I quit upgrading when I retired.
If this is close to what you want to do and need more info, just ask and I'd be glad to do a step-by-step example.
(Note: I make no claim to expertise with Sketchup, so there may be better ways to do the same thing.)
Paul Kramer
Here's a pic of lamb's tongue
Paul Kramer
>John,
They are more complicated than a mere curve. See the pic below. It shows both a 'face' view and a profile view.
HTH,
Paul
Re: Here's a pic of lamb's tongue
>OK. The actual profile doesn't matter in the technique I mentioned.
Robert Henderson
>I can't speak to the quality of the book, but they just came out with a "Sketchup for Dummmies". I just ordered it from Amazon.com
On the right track
Tony - Memphis
>That's pretty much it. The profile I want is different, but like you said, same idea. I was trying what you described, but getting frustrated with it. This program is really backwards from anything I've used (Pro/E, AutoCAD, etc.), so it's been quite a mindshift for me. Well, at least you verified I was heading the right direction. I'll play with it this morning and see what I can do. I may ask you for some more help!
Oh, I'm using the free version because I have been so frustrated with it. If I can manage to get used to it, I may buy the pro version. 99% of what I draw is 2d. 3d takes so much longer, I spend more time drawing/modeling than I need to. For 2d, I am still using IntelliCad (AutoCAD look-a-like). Great program and it was free too.
Thanks very much for the help.
Tony
book
>I haven't seen that one, but I can strongly vouch for "The SketchUp Book" (Bonnie Rakers) sold by @Last.
