Where Hardwood Comes from-9B preparing for kiln
Bill Tindall, E.TN
>Part 9B Preparing Lumber for the kiln I am going to dwell more than usual on this topic because it is important to anyone drying their own lumber. There are two more installments to come- 9C on predryers and 9D on the kiln drying porcess.
In the past lumber was usually dried by the end-use customer but now it is common for the saw mill to integrate drying into their operation. Once the lumber comes off the green chain it must begin the drying process immediately unless it was dipped in the chemical bath. Otherwise, susceptible species like maple and other light colored woods can begin to develop mold that will stain the lumber gray or black within a day or two in hot weather. Getting the surface dry is sufficient to prevent mold growth but if the moisture content of the interior is not brought down fast enough enzymes within the wood make chemicals that darken the lumber when it dries. This defect is called �chemical stain� and it can be confused with mold stain. �Sticker stain� is one or the other of these stains that occurs under the sticks used for stacking lumber. It is usually the result of having used sticks that are not dry.
The first step in the drying process is to get sticks between the layers of lumber so that air can freely circulate between the layers. This picture shows some stacks that just came out of the kiln with the sticks still in place. The important points of preparing these stacks are illustrated in this picture. The objective of the sticks is to enable air circulation between the layers while adequately supporting the lumber so that it stays flat during drying. In this case the sticks are 8� long and �� thick, though I have seen these sticks up to 1� thick. ( Thicker sticks enables better air circulation but the kiln will hold less lumber) The bottom packs are cherry and the sticks are 12� apart which is closer than I have seen in most cases. This operation, Mountain City Hardwood, told me they stick cherry and maple every 12� and other species at 2 feet. It is common to see stick separation of 18� at other operations.
Some mills use kiln dried sticks made from domestic species but this mill uses foreign woods that don�t pick up moisture as readily as domestic species. At this mill grooves are milled into the sticks to promote air circulation, and hence, more rapid drying under the stick. The second picture shows these grooves in a 4 x 4 used to support the stacks.
It is essential that the sticks be aligned one above the other to properly support the layers. These piles are assembled by automated stackers and they are perfect. When these stacks were in the kiln the 4 x 4�s that enable the fork lift tines to go between stacks would have been aligned exactly under the sticks. Note that the bottom layer has already begun to sag because it is not supported under each rank of sticks by a 4 x 4. Any warps and wiggles before drying will be flattened by the moist hot environment of the kiln provided the lumber is properly supported in the kiln. But, any bows set in the hot lumber when it leaves the kiln will be there forever.
Logs are cut in even foot increments so most lumber will be even foot increments. However, as a result of trimming some odd length lumber is produced. Lumber stacks are assembled from just one even length of lumber plus the odd length 1� shorter. These odd lengths present a problem for supporting the layers. This problem is usually dealt with by alternating the end alignment of these odd length pieces when the stack is assembled. Note in the top pack of 12� long poplar the sticks are spaced every 2 feet except at the ends of the pile where they are spaced one foot. This �extra� stick one foot from the ends support the ends of the 11� long pieces in the interior of this pack. The odd lengths should be in the interior because they are supported better there.
