Butterfly keys
WRF
>Anybody know/can post some techniques for making functional Butterfly keys? Not routered inlays but full thickness keys that would bridge the gap between 2 separated boards of a tabletop or bench?
Butterfly keys
WRF
Re: Butterfly keys
>Your inquiry begs the question, "Why?' Butterflys offer an attractive way to give the appearance of holding a split together or reinforcing joinery. Aside from bragging rights to full-through construction, there is little, if any, structural justification if the wood is well seasoned. And if the wood isn't well seasoned, why is it being used? I have used butterflys on a number of projects, never making them more than 1/2 inch thick, and have never experienced a failure. It's difficult enough getting a perfect fit for a thin butterfly, so why ask for more pain for no gain?
I cut the butterfly on the band saw and use it as the pattern to lay out the mortise for routing and chiseling. I'd use the same approach for a full-through version.
Clint
Might want to ask this guy
>He must know where he got a spare set of ignition keys made for this :)
Happy Woodworking!
Re: Butterfly keys
>Geez, I never knew they came with locks! Must be really small ones though.
PS
>Eagle America has a template for cutting butterfly inlays using a template and router inlay fittings. They also sell a router bit to mill key stock. Both are listed on their website
Re: Butterfly keys *LINK*
Lee Schierer - McKean, PA
>As I understand it you can make the key with a special router bit (see link) and you make the slots in the mating parts with a 14 degree dovetail bit. I'm sure it would take some practice to get the joint perfect, but a a few test pieces shold show you how it is done. The router bit may also have instructions with it.
Basically you are making two sliding dovetail joints face to face.
For strength you may want to change the grain orientation of the key to run from top to bottom rather than length wise.
One of the woodworking magazines, possibly, Fine Woodworking did an article on them but I don't know the specifics.
Re: Butterfly keys
WRF
>Thnx all! :)
