Making a barrell chair
Alan Young
Alan Young
>I might be making some barrel chairs...
If I do this job I'll make the lower curved based and the curved arms from bent laminations...The curved back will be solid wood edge glued upwards together with wider sections off set backwards to create the back bend...
I anticipate sculpting the front of the back rest with a series of rasps and files..maybe even a belt sander... But what about the back side? What kind of scraper, file etc.. would allow me to make a smooth surface over the compound bend on the backside?
Alan
BTW Col George.. I expect a decent pun or two from you in exchange for a helpful suggestion! :^)
Re: Making a barrell chair
Kneale Brownson in sunny N. MI
>I'll try to beat him to it--should be a barrel of fun.
Why couldn't you smooth the outside the same way you'll smooth the inside?
Robin Corell, in Atascadero CA
>That is a copyrighted design still in production. It is a beautiful design and I too have looked at it for ispiration. Perhaps a design based on it, and possibley more comfortable would be a better choice. Also a chance for you to show of your own design skills.
Robin
I would use a 90� angle grinder
Keith Newton
>for both sides. If you want to follow that with a belt-sander, I sometime band-saw a little arc piece which I slip under the platen of the sander.
You would be sanding with the belt cutting across the grain, but if you follow this with a random-orbit sander, it should not take long to get rid of the scratch if you are using something like a 100 grit belt.
Alan Young
So are you saying I shouldn't or can't make it?
Alan Young
>If I google "barrel Chair" there are many... well at least several places to buy one...What part is copywritten?
I'm not arguing here Robin just don't want to get in trouble or jump through too many hoops or barrels to make these.
Alan
>One tool I've used with reasonable success in doing funky compound curves like that is a Lee Valley Low Angle spokeshave. I've also used a 4 1/2" angle grinder with coarse grit sandpaper. YMMV.
Re: So are you saying I shouldn't or can't make it
>All of FLW's designs are copyright protected and controled by the foundation trust. Many of his designs are licenced and produced by various companies. the chair in question is sometimes refered to as the Tallison barrel chair because he used it in his own home in AZ.
Legally you can not make and sell the chair as drawn. some people will still do it either due to ignorance of the law or in open defiance. For me it comes down to the fact that I have worked hard to come up with my own designs and they are what sets me apart from the stuff sold at IKEA. I don't want someone making an exact copy of my work, not even for personal use as that is one less that I could have sold.
Now to use that chair as the inspiration for your own original design is something that is legally and etically ok to do. Be awaere that it is necissary to make sobstantial changes to give it your own mark of originality. it is fine to be able to see the "roots" of the design though.
I was at the shop of a friend and was admiring a rocker that he had done that was based on the famous Bauer chair from the 1920's the original is made out of tubular steel with strips of leather. my friends interpritatiopn was made out of monolitic slabs of wood and was a rocker but the heritage was still there and it was a wonderful and original interpretation. I especially enjoy seeing this type of work. The one I have been working on in my shop is my intepretation of a Danish modern foot stool which, is that designers interpretation of an 3500 year old Egyption design.
I am not saying don't make a barrel chair. What I am trying to say is don't make that exact barrel chair, but do make one of your own original design based on that one.
Robin
Alan Young
Thanks Robin for the clarification and
Alan Young
>there are not as many "for sale" as I had been thinking...several included phrases such as "Barrel Style" ect..
Thanks for the heads up....We'll see what develops.
Alan
If you want suggestions
Keith Newton
>If I were to use this chair for inspiration. I would make it elliptical, with the long axis across the seat, and the short axis front to back.
I would have the arms turn back in as they come forward, and I would add some top to bottom curve in the back slats.
There are plenty of other nice simple little details that could add a nice touch as well.
Of course you will owe me royalties if you use these ideas. Ha
Alan... A Different Approach
HC Sakman
>Hi Alan,
I was thinking about it (no, it didn't hurt!;-) and I think the back can be built (rough bandsawn then glue (6~7 inches high) the layers up, no "brick" effect though. 1" or so overlapping joints can be where the four cuts will fall.) on 22" diameter plywood and turned on a lathe. One set-up will yield to 4 chair backs!
Chico...
Seems like...
Don Orr
>...they really have you over a barrel here about the design ;-))
I say use whatever tools and techniques you have at you disposal to get what you want.
Alan Young
I had to think about that for a while
Alan Young
>till I understood. It did hurt!:^)
That is a good Idea. I'd need a bigger lather though..I think my lathe can only handle a 12" diameter....
Alan
Alan Young
Interesting concept Keith....Maybe the base
Alan Young
>would need to be deepened though for stability? Lots of curves seem to be entering the picture...
I will add you to my Multi Level Marketing System...:^)
Alan
Tony - Memphis
>There is an article in the last FWW on how the chair on the back cover was made. The guy coopered it with different shaped staves. My wife has a very similar chair (in the attic cause I don't like it!). It was factory made I'm sure and is all laminated best I can tell.
Tony
