searching for a good countersink
Bruce, a MN Galoot
>For years I've been using the standard six-fluted countersink that, I think, was developed for metal working. Too often, I get a six-sided countersunk hole in the wood. So I'm looking for a really good countersink that's designed for wood.
Does anyone have one? Which do you recommend?
Thanks.
Bruce
Re: searching for a good countersink
Carol Reed - in Nebraska
>A single flute countersink available at tool stores. Been using them for years. Work very well in wood and plastics. Available in different degrees - 45, 60, and 82 (I think). I use the 45 most of the time.
Hank Knight
>Brice,
Lee valley sells two good ones. The first is a single flute cone-shaped countersing made(I think) by Beall and. The Lee Valley Item # is 44J21.01. The second is an HCS (don't know what that means) countersink that looks a bit strange but works very well on wood. Actually, bioth work well on wood much better than the 6-flute star countersinks you've been using. I've copied the photos of both from the Lee Valley catalog that I'll try to post below.
Beall Countersink, Item # 44J21.01:
Photo Sharing and Video Hosting at Photobucket
HCS Countersink, Item # 06J50.20:
HCS=high carbon steel
Howard Norman
Thanks, Howard. Mystery solved.
Hank Knight
It's probably not your counter sink!!
Lee Schierer - McKean, PA
>I thought I had a simmilar problem with my countersink. In certain woods and metal I would get fluted countersinks instead of nice smooth tapered holes. Then I noticed when I used the countersink in my hand drill the contersinks would be fine. When using the same contersink in my drill press I would get the fluted holes. After a bit of testing and investigation, what I found is that my drill press quill had some play between the rack ann pinon that lowers the quill. As the contersink would cut, it would relieve the downward pressure against the face of the gear and the play between the teeth would let the countersink chatter producing the wavy sided countersinks. The permanent solution would be to eliminate the play in the teeth, but that will be quite costly, probably as much as replacing the drill press.
The work around solution was to tighten up the quill lock slightly so there was more drag on the quill and then the countersink would not "self feed" quite as much so it couldn't chatter.
Test your drill press by holding hte handle in place and then push up and down on the quill. Any free play will allow chatter.
Lee
Re: I like 2 of them
Brian in Brighton
>I like the ones that your describe for very hard wood or plastics, but for softer woods I like the kind that has a single hole thru it at an angle to the countersink. The latter produces a very smooth hole in most anthing.
Brian in Brighton
Tim Caley - North Litttle Rock
>Have you tried making the countersink before drilling the hole? I find that I get much cleaner countersinks doing it that way.
Re: It's probably not your counter sink!!
Bruce, a MN Galoot
>That had never occurred to me, Lee. I'll check for play in that quill. I had always thought that the drill press would produce more consistent results, but I guess not. Thanks.
Bruce
Bruce, a MN Galoot
>Thanks for the recommendation and vote of confidence. I'd looked at those before, but wasn't sure. What I like to do is park one in a brace and leave it there.
Bruce
Bruce, a MN Galoot
>On occasion I have made the countersink first. It does produce very good results. Guess I'll just have to work on my technique.
bh
Bruce, a MN Galoot
>I'll get one of the single hole models. It's good to know of others' experiences.
bh
Bruce, a MN Galoot
>I have a cheapie, single flute model like you describe, but it's so dull that it tears more than cuts. Maybe I'll have to figure out how to sharpen it.
bh
Re: searching for a good countersink *LINK*
Bob Lemon
>Bruce, Here's the one I like. It is adjustable with depth stop. I found this one on EBay through a search.
Adjustable Countersink
Bill Falberg
>I use a three-fluted countersink for everything other than steel. They're available thru MSC and Grainger in various widths. Six flutes is too fine for wood and one is too coarse. They work best under pressure, so the smaller your pilot hole is; the smoother your ctrsk will be. I think it also helps that the three-fluters spiral into the work. Try one.
Another vote for Lee Valley
Jim Dillon
>Bruce,
I have both Lee Valley countersink bits that Hank posted and they work very well indeed. I also have the common six-sided countersink bit and have to say that I have used it a lot as well. For regular stuff, I use the six-sided bit; for smoother boring, I pull out the Lee Valley stuff.
Jim
Ed O'Neill
>I have a jar full of Stanley countersink counterbores I've accumulated over the years. It has an adjustable collar for depth. You can countersink or push it to counterbore. You can get the matching plug cutter. Haven't bought one in years but it might be what your looking for. Ed
tstock
>If the goal is just to countersink a hole for a bung or plug, use a good Forstner for the cleanest edge, then finish the bottom of the hole with just about any countersink to allow for the screw head.
If you want to chamfer the edge of a hole, a Weldon countersink/deburring pilotless cutter is the best bet (check on the MSC or Enco sites). I use these for chamfering bridge pin holes in rosewoods and ebonies, easing hole edges in aluminum and Lexan, and on most materials where a polished, true cut is needed. The Lee Valley single hole-style flute tool is similar, although I doubt you'll beat Weldon for range of sizes and performance. Woodcraft used to carry the Weldons, but now stocks an Asian knockoff which does not work as well in highly figured woods. The Weldons are available in HHS which can be resharpened.
