OT : Plastic
OT : Plastic
OT : Plastic
>SWMBO has decided that she wants the dining room table with 1 less leaf in place. Not a problem except the 1/4" plexi sheet on top will have to be cut. The sheet is 44x100+".
Questions:
1. Is this table saw time?
2. If yes, which blade (course, fine, coated, etc.) to use and what feed rate (slow fast, etc)?
3. Should I score and snap instead?
4. If so, do I score both sides or just one?
I'll be doing 2 cuts to allow forr the leaves' replacement.
Thanks for the help.
mm
Re: OT : Plastic
Re: OT : Plastic
Steve Mackay
>When I do it on the TS I use just the stock blade. But DO NOT hesitate ! run it RIGHT THROUGH that sucker. The stuff'll start melting and will close the cut back up on the out-feed. Don't use a jig saw unless you want to do a lot off sanding on the edges.
Re: OT : Plastic
Re: OT : Plastic
Kneale Brownson in sunny N. MI
>You can score plexi and break it just like cutting glass. Works best if you use the designated carbide scoring tool like they use at the hardware/glass companies, but a sharp utility knife will work. You may need to run a utility knife blade along the same line several times.
Re: OT : Plastic
Re: OT : Plastic
Gary Camp, Bend, Oregon
>I cut Plex all the time at work, 60 tooth woodworker II works just fine. You will probably want to block sand the cut edge, be aware the edges will be very sharp. I had a co-worker who could get the cut edge to look the the flat surface IF I gave him enough time to do it, 120 grit all the way down to automotive polish.
On a side note, I hand an old hand held jig saw that I could stack two blades side by side in the blade holder. The incresed kerf width help the cut as did a stream of air on the blades at the cut line.
One more thing, use wide masking tape on the cut line on both faces of the plex if it doesn't have the original paper on.
Oh yes, eye and hearing protection is a bigger must with plastics and the "sawdust" is extra clingy
gcl
Re: OT : Plastic
Re: OT : Plastic
>Mark I'd do it with a router. I've cut a lot of plexiglass on the table saw it cuts cleanly and easily but that was plexi with the protective cover still on. It would be very easy to scratch the glass and would be hard to get it out.
With the router and a small bit you could make several passes. Use a wooden guide clamped to the plastic. The first would be to just cut it. It will try to wander because the bit is cutting on both sides. Wandering away from the bit is OK. Then after the first pass you can clean it up perfectly on the next pass.
You could also cut it with a jig saw first and then clean it up with the router. Put wide masking tape down to protect the surfaces from scratching.
Re: OT : Plastic
My 2 cents
Charles Wiggins
>Steve, Kneale and Gary have given good advice. My experience is cutting plexi on the TS. I use a fine-tooth blade designed for plastics. If your stock is thin (less than 1/4") run the blade up to full height and the downward motion will help hold the stock down to the table at the point of cut. Sometimes, if the blade is too low and the plexi starts to bind, it can start to climb the blade. As stated before, keep it moving so it doesn't heat up and melt.
Couple more things: Plexi will scratch if you look at it crooked. CIf this is a concern, cover the 'down' side with some craft paper, wrap it over the edges and tape it to the top to keep it secure and, like Gary said, tape off the cut-line on both sides.
Re: OT : Plastic
Edge Finishing After the Cut
Garrett in Victoria
>When you've cut the sheet, the edge will be rough and opaque. You can make it smooth and transparent easily.
On small sheets, I usually run the edge over the jointer to get it smooth, but since yours is too big to do that, you can either use a sharp block plane set very fine, or a file.
When it's smooth, take a butane torch (plumber's torch) and holding it far enough away so that only the tip of the flame is touching, gently and slowly move it back and forth caressing the edge. You can always apply more heat if necessary, but if you get impatient you'll ruin the edge. You'll see the edge turn from opaque to transparent. If you're doing it properly, 2 or 3 passes will do a professional job.
Cheers, Garrett
Re: OT : Plastic
Gotta ask
Dave Peebles Lyons, Ohio!
>Mark
You are wood guy, why do you have plexy on the table?
Please don't tell me you have plastic covers on the sofa.:)
Just messing with you, because I have no answer to your question.
Best wishes,
Dave
Re: OT : Plastic
Since You Asked
>Morning, Dave,
The plastic is there to take the wear. Since my office is in my house, the table is used for document review and client conferences and meetings. Without the protection, the burl veneer top would have been wrecked long ago.
No, don't have the upholstery sealed, but then the cats have that reserved anyway.
mm
Re: OT : Plastic
Thanks Folks
>Given the size of the sheet relative to the size of my shop, I'm going with the score and snap option for the center cut but with the addition of a hand-cut notch at the two edges to try to insure a clean break at the ends. It'll be lots easier to do the other two cuts on the table saw if I screw up the snap. That way, all I'll have to replace with be the two sections to fit the leaves.
Thanks again
mm
Re: OT : Plastic
Re: OT : Plastic
Larry Clinton
>Mark, I have cut plexiglass both on the table saw and bandsaw. Either work well with the proper blade. I have also scored and snapped some, have broken / chipped a few corners this way, but it may have been I didn't have it scored deep enough. One thing I have discovered recently - the Micromesh sanding disk sets sold by Woodcraft (and other places) work amazingly well at polishing acrylic to its original clarity. I purchased an older Powermatic 90 lathe from a school sale and restored it completely. The acrylic shields were scratched & splattered with finish to the point they were almost opaque. I (after trying some scrap samples) ended up sanding them clean with 320 grit then moving up in grits and finishing with the Micromesh abrasives - using my Bosch ROS. They turned out great.
Re: OT : Plastic
Hadn't heard the torch trick. Thanks !
Steve Mackay
