Assembling a lumber stack for drying
Bill Tindall, E.TN
>Finally after nearly a year of waiting the mill called to tell me the quarter sawed poplar (for drawer sides) was ready to be picked up. As is often the case in these affairs the sawyer had forgot that I wanted it 6/4 for resawing and it was sawed 4/4. It was sawed different from what I usually do. Apparently he took 5 cuts out of the middle of the log yielding 5-22" wide boards that are not easily handled. Then the slab from each side was turned down and sawed into narrower material that will be easier to deal with. That purple on the end will soon be faded to brown which suits me well.
The picture shows how I stack the lumber for air drying. I have 4 x 4's on the bottom and sticks every 2'. The lumber sat dead packed from Friday till Tuesday and even though it has been cool to cold the surface was already starting to stain from mold growth. Had it been summer it would have been black by now, but as it is, it is only spotted gray and not penetrated much below the surface. I might have sprayed it to kill the mold but it is only drawer sides so I put fans to the side of the pack as soon as it was done. The fans will quickly dry the surface and then mold growth is no longer a problem. In the spring this stack will be dry enough to move to the barn loft where it gets hot and will dry to less than 10% moisture content and be ready to use by mid summer.
In the next installment of the hardwood production series I will show how stacks are made at commercial mills.
