OT Electrical Question
Martin from Granbury
>So, there I was, changing a bulb in my ceiling fan. I was trying to be a good conservationist, and I was replacing the burned out bulb with a new "energy efficient" compact fluorescent bulb that costs $7 a pop.
So, I unscrew the dead bulb, or at least I thought I was, when I hear a pop, see a spark, and the other three bulbs go out. I know, I know, I should have had the power off to change the bulb, but that's water under the bridge at this point. Besides, the room would have been a little dark.
Instead of unscrewing the bulb, I somehow twisted the glass part of the bulb out of the metal socket. So, now I had the socket part stuck in the lamp. I took the precaution of turning off the breaker, and then removed the stuck part with needle nose pliars. This is not the first time I have experienced this. I wonder if the bulbs were cheap and break easy. Anyway, I put in the new bulb, turned on the breaker, and turned on the switch. Nothing. Still very dark in the room.
So....did I fry the lamp portion of my ceiling fan? (Fan works fine, BTW, thanks for asking.) If so, how can I prove this without buying a new lamp portion? Note to all the helpful readers: I am an electrical idiot, so please speak slowly and in simple terms.
Thanks guys (and gals) I know I can count on you.
Martin
