Varnished Pine Fading
Jeffrey D. Rose
>I was at a friends cabin this weekend, beautiful place looking over the Mississippi and all the fall colors. The interior is almost all pine, including walls. In a few rooms the South sun hits the walls hard during the day and the previous owners had pictures in places that are now exposed. As you can guess you can see right were the pictures were hanging. The pine has varnish on them, appeared to be interior, so no UV inhibitors. I really can't think of any solution to get the areas to blend in with the rest of the wall besides sanding. Anyone have any ideas how to get the lighter areas, where pictures were to blend with the rest of the wall?
TIA
Jeff in Iowa.
Re: Varnished Pine Fading
Hang more pictures.
Ron Hildreth, Alta, Iowa
>Jeff in Iowa,
I'm not sure, but I think the very first thing to do would be to clean the surrounding areas first, maybe with TSP or a good cleaner that won't leave a residue. This will give you a better idea of what you're up against. Any possibility the former owners were smokers? Since my wife and I quit a few months ago we've been busy cleaning everything to get rid of "yellows" that nicotine left. You just can't believe how much cleaner my life is, now. Anyway, could be that you'll luck out and find that it's just cigarette smoke (or cooking smoke) yellowing, that the TSP should take care of. Just some thoughts, here, before you go to all the trouble of sanding and refinishing!
Ron in Iowa, too
Re: Sunlamp on light areas, perhaps.
Al Stokka - Cambridge, Iowa
Shadows on the walls
Lee Schierer - McKean, PA
>What you have is sun shadows in the wood. The wood behind the pictures has not darkened with age because it has been kept in the dark. The rest of the wood has darkened with exposure to light. There is no cure short of sanding all the wood down or hanging pictures over the same areas. You can see the same thing on cherry and walnut tables and furniture where lamps or other opaque objects have been placed before the wood has a chance to age. Leaving the paler areas exposed will allow them to darken, but most likely they will never match the original wood.
Lee
