Epoxy filler hi-jack
Brian in Brighton
>OK, this is a new thread, but the Epoxy filler is just so far down the list.
I have a nice piece of walnut that hase a couple knot holes in it, it will be a mantle someday so I want to fill in the holes around the knot. My problem is that I went to the Denver Rockler and the sales guy (not Rich) led me to the 2 part mix stix. I was thinking that I had seen where a 2 part clear epoxy can be used, but he did not know what I was talking about.
So I have 2 questions.
What brand or type of epoxy have you used successfully in this application?
What are any finishing misteps I can expect. I plan on using a watlow oil with a rub on poly top coat. Will there be adhesion problems?
Brian in Brighton
Re: Epoxy filler hi-jack
Howard Norman
>I have used two brands of two parts epoxy for filling holes. I have used a lot of the West System epoxy for this purpose. I have also used the 5 minute dual tube systems that you find at WalMart and your local hardware stores. I have successfully used powdered graphite, the kind that you use as a lock lubricant, as a dye with the epoxy.
Howard
Laser toner works well too
Chad Pearson
>If you take a cartridge of toner out of the printer at work you can usually find a good supply of black carbon for dying the epoxy black. I have used this many times for filling holes in cherry. I think just about any type of epoxy works. The only issue I have had is avoiding bubbles in the epoxy. A quick search through the archives will help you solve that problem.
>Brian I have used West system and system 3 epoxy plus a wide variety of the syringe type epoxies. The all work. I have used powdered chalk, powdered tempera paint, shoe dye and analine dye and coffe grounds to color it. I like the shoe dye because it takes very little and it doesn't change the viscosity. The powders make the epoxy thicker which can be good or bad depending on the application.
Keith Newton
>The brand of epoxy is a non-issue. If you want to use any clear epoxy, my favorite method is to add the sanding dust from my belt-sander, and mix to the thickness of peanut butter.
Smush it in the hole, leaving it higher than the surface, then sand it flush after it has cured. Someone usually suggest mixing sawdust, which is fine if you would like for it to look like partical-board.
You can mix universal tints of any color to the filled epoxy to adjust the color. If you just add the color to straight epoxy, it will look more like colored plastic, and if it has much depth, it may generate enough heat that it will boil when it kicks, which can cause the bubbles.
Larry Clinton
>I use the 2 part 1 hr epoxy that comes in a 2 tube syringe from Wally world - I also use the black Rit dye from same store. Any epoxy will work very well as it is not a structural application. I have used the quick set type (same brand) but does seem to have more problems with bubbles. If bubbles show up after sanding, I just mix a little more and skim coat the surface - filling any voids. This has worked well for me on several pieces of oak trim my son used in remodeling his home. I sand the surface to 220 grit with a ROS. After sanding the epoxy will look somewhat dull and grey, after a finish is applied it becomes quite glossy - looking just like a sanded firm knot. On one occasion I was finishing up some trim and didn't have any black filler material. I used some India Ink to color the wood under the missing knot and filled with the clear epoxy. It looked rather unique like a deep pond with a black bottom. My son's wife loved the appearance and dictated the board be installed as a face trim board over an entryway between the kitchen and Living room :~).
