>Can anyone comment on how well plastic resin glue works for end-grain joints, like a box made w/ miters? I'm especially interested in comparisons to yellow PVA. I typically (but not always) reinforce these joints but I'd be interested in knowing non-reinforced holding power.
>To me, the strength of an unreinforced miter joint isn't trustworthy regardless of what glue you use, so I've never tried it. But, if you're intent on this, I'd recommend making up a couple samples and torture testing them to see what to expect. Plastic resin glue sets up hard and strong and is highly water resistant, but it doesn't bridge gaps well, so the surfaces need to be in very close contact. Since endgrain is mostly open pores, at the very least you would want to smear some glue into the pores to fill them before actually gluing the joint itself.
If you try this, please let us know what you find out. I'd be curious.
