Magnetic touch latch, need nice one
Link Van Cleave
>I want a nice one for a fancy pants cabinet I am making. Something nicer than the plastic ones that are generaly available. Maybe in brass. Does anyone know if such a animal exists.
Thanks.
Re: Magnetic touch latch, need nice one
Thomas S Stockton
>Link,
I've looked before and came up with nothing they all seem to be the same cheap plastic ones. Sugatsune makes a plastic one with a stainless steel cover that looks a little better(model SML page 120 of their catalog). I personally hate the things but sometimes it is whats needed on certain jobs. if you find a real nice one let us know it would be great info.
Tom
Bart Goldberg
Re: Magnetic touch latch, need nice one *LINK*
Bart Goldberg
>Link,
Check out Lee Valley's selection. They have some in Brass.
Bart
Catches At LV
JohnKJordan in East TN
>How about making your own?
using a magnet for door catch
Not the same
David Yoho
>John, what he's looking for is a magnetic touch latch - one that, when pushed, opens a door, but will hold it closed when not in use.
Different from using magnets installed in the door and frame.
David
Keith Newton
>Is there a reason that you must have "magnetic"? I have not shopped for them for quite some time, but all I could find then were about as fine as a cheap ball-point pen. all that I have found that I like is the little roller mini-latch from Haefele.
They are small, and easy to hide, and work well. Not very easy to index, but If you try them, come back and ask for tips, and I will offer some suggestions.
>David is correct, it is not the same, but I have a further refinement on the rare earth magnet Idea.
I bought 10mm magnets. I used a forstner bit to drill a hole in from the top of the cabinet, into the rail, but not through. As close as I could go, without cutting through. I glued a magnet into the hole. Then when I assembled the doors I built a matching magnet into the style and rail of the door about an 1/8" down from the top. I was careful to be sure the magnets lined up with each other and had the poles correctly aligned. The doors close as if my magic and there is nothing to see.
>Yes I realize it's not the same, but given the choice, I imagined I might prefer hidden magnets to latch the door instead of the cheap magnetic latches I've seen for sale.
