Table extension on cabinet saw
Bill H-Evansville, IN
>I recently bought a used unisaw and the extension table was at a sever downward angle from the saw. I leveled the table with the levelers on the table legs. Now the rail is a good bit below the table and the fence doesn't sit flush with it's rail. Should I level the fence rail with spacers or is there some way to adjust the rails on the table saw the extension table is level but the table top is a uniform height above the table saw rails? I hope I have explained this correctly.
Thanks in advance,
Bill
Re: Table extension on cabinet saw
Dan Mitchell
>Generally, you attach the rails 1st, setting them a given distance from the table top surface as measured from the top to the horizontal leg of the angle iron. This distance may vary from saw to saw, on my Powermatic it's 2 27/32. You make sure the angle is the same distance from the top all along its length, and is thus parallel to the top. Then you set the extension table such that it is level with the table top along it's entire width, then bolt the extension in this position through the holes in the angle iron. You might want to go to the Delta site & see if you can download a copy of the owner's manuals (may be separate ones for the saw & fence).
Dan
