>I've finally decided that I need a dust collector. I would use it for my portable planer and my router table (and a jointer one day). Any recommendations for a portable dust collector (not a shop vac.)?
>I have, and like, the Delta 50-760 dust collector. It was highly rated in a past Fine Woodworking Issue, and I bought it because of that recommendation. It sucks a lot of dust in, and the felt bag doesn't seem to let much of the dust through (nevertheless I always wear a dust mask to protect myself against the really fine dust).
My only issue with it is that the fan is integral to the dust collector assembly. This limits other possible uses for the fan, such as using it as a spray booth fan or a ventilation fan.
>ps. The Delta 50-760 runs on 110VAC and has never tripped my 15 amp breaker. It will not, however, run on my reel extension cord which has a built in thermal overload in the receptacle. I don't think you can get much more fan capacity without going to 220V.
