>In reading the string about Zinsser Shellac Shelf life, it made me wonder how long shellac flakes can be stored before use. Should I keep mine in a refrigerator? I currently store them in a metal cabinet in my garage, but it is susceptable to the hot, humid Arkansas summers.
>Buy the quart or gallon paint cans from the Borg or hardware store. Get some silica gel dessicant packs and put them in the bottom. Store the shellac flakes on top and seal the can.
To regenerate the silica gel, heat the packs overnight at 200-220 degrees F.
I've used this method for a couple of water sensitive materials for years. If you can get the indicating silica gel packs (ones which turn pink when moist and are blue when dry), that would be good.
>what about putting the flakes in a paint can ( they now make gallon and quart cans out of plastic" and introduce CO2 into the can to displace the air and sealing the can?
>Shellac is acidic and can corrode metals. It is best to store flakes in a cool dry place in a non-metallic container. Air is not particularly a problem, so it does not have to be air tight. It is the moisture, heat and sunlight that you want to avoid. Theoretically you can store flakes in paper or cloth bags if you are in a space that is moisture controlled, but since most are not, we use air tight cans not because of the air, but because of the moisture that comes and goes in the air from season to season and from day to day. FWIW, I store mine in plastic cans with plastic screw on lids.
>moved and put them in storage. When I took them out they were a solid block. They didn't seem to be armed, I just has to make a mortar and pestle to grind them up to disolve them in alcohol. I am still grinding.)-:
