Coloring Epoxy
Jim Orasky in Davenport IA
>Need to fill some small defects in white oak. Thought about using epoxy colored with transtint. Anyone ever try this. Does it affect the bonding?
Coloring Epoxy
Works Well, Bond is Fine
Re: Coloring Epoxy
Brian in Sandusky, OH
>yes...it will work fine.
I used that exact formula to fill come voids before turning a bowl...turned out real nice.
But it will be translucent....not sure it that's your intention.
Re: Coloring Epoxy
Ken Platt (North Granby, CT)
>I've colored epoxy with all kinds of stuff, but never transtint. I would think it'd work, but maybe some of the sawdust from the project itself would be better and cheaper. Also, don't forget the old trick of putting a drop of CA glue in the defect and then sanding with fine grit paper. I use old worn out sandpaper since the piece ends up clogged with glue/dust. For small defects that I want to vanish, this trick is one of the best in my trick bag.
Ken
Re: Coloring Epoxy
>I'll give the transtint and the sawdust both a try. Thanks for the advice.
I keep reading Saw-dust
Keith Newton
>Which I think is too coarse to use for filler for epoxy. However I use dust from my sander bags regularly. It will usually come out a darker color than the raw wood, but then that is how I think it should look.
Most of the time, I mix about half colloidal silica and dust.
I also like the CA and dust for smaller quicker filling. and have used universal tints with bondo which is fast also.
