Veritas - Innovation in Tools
Determining wedge size for Wedged Tenons *LINK*
JEB
>Hello all,
I need some math help!! I'm probably over thinking this, but before committing to the job, I'd like some imput...
Here's the deal.. I'm building workbench, and the making "Wedged" Mortise & Tenon's (as in Ian Kirby's "Arts & Crafts Workbench" from the October 2004 WJ mag pull-out). I'm having problems figuring out the dimensions for the wedge, and the additional expansion gap for the wedge in the mortise.
From the minimal directions listed for creating the mortise and wedge, he states:
1. The kerf: the size of the the kerf in the tenon as 3/32", 1/4" in from either side.
2. The wedge-- he states that he (I'm quoting) "decided to wedge out the longer rail joint at 5/16" and the end rail joint at 1/4"." and "saw a wedge with a 3/32" blunt end" (his tenons are - long rail 3 1/4" L x 5 3/4" W and his end rail 3 1/4" x 3 1/4").
3. He also states that for his 3 1/4" tenon, he is using a scrap board 4" long to make his wedges.
Elsewhere (on another website) someone had shown on his layout for his Wedges "Gradient 1:8".
My Mortise & Tenons are similar in size as above (long rails 4 1/8" L x 5 5/16" W, and short rails 3 1/8" L x 4 3/8" W), so I'm figure I'm OK with using a similar measurement, but... I don't know what it is??
BUT... If I understand it... I can do this, and it will work:
1. I make a wedge a) 3/32" wide at the inside end; b) about 1" longer than my kerf is deep (ex 4 1/4" for a 3 1/4" deep kerf).
2. Using 5/16" as my wedge size, layout and cut the wedge so that at 3 1/4" from the inside end of the wedge, it is 5/16" wide (where it is the (same) length as the kerf).
3. Cut a test wedge.
4. Use the angle on the test wedge to make a guide block (for my chisel) as the angle guide to cut out the angled area of the mortise.
I did a quick layout (not to scale) for a sample and listed the link in the "Optional Image URL" below. Hopefully it will show up for you to view. Check it out to see if it makes sense.
Thanks...JEB
JEB's (fishing) Website
Re: Determining wedge size for Wedged Tenons *LINK*
Looks good, Jeb
>The only thing I might suggest is that you don't clearance the ends of the mortise the full 5/16". You want the wedges to squash those 1/4" tenon wings tightly against the ends of the mortise. You need to figure on wood compression to do that.
Ellis Walentine, Host
Re: Looks good, Jeb
JEB
>Thanks Ellis!
I decided to make a full size sample to check out how well the wedge fit. As you suggested, I realized that I need to make the 5/16" width to be shorter down the wedge. When I installed the wedges, they were tight. Although I couldn't do it with my fingers, I did it with pliers, I was able to pull the wedges out without applying a lot of force because the wedge had bottomed out just as the 5/16" section of the wedge got into the slot. I figured I'd better resize the wedge just a bit to keep it from bottoming out.
After I did that, it went in nice and tight, and it's not coming out!
I'll try and remember to come back and post a pic when their done. Of course, thats as, long as they look good. ;)
Thanks again...JEB
