resaw which way?
resaw which way?
resaw which way?
Paul Waddle
>I've read Burton,Dugenske(sp), and Bird on resawing on the bandsaw,but I miss a point and can't find it again. Perhaps someone will assist and explain the rationale. Its to do with resawing veneer: Which side of the fence should the thin slices of wood come off? If you leave the fence set,it would seem the better,but somewhere one of these learned gents stated its better the other way,even knowing you must reset the fence each time.(I assume this would not be a problem-just use an appropriate width(but won't the lead comphensation complicate??) Thks,pw
Re: resaw which way?
I'm kinda guessing here but...
Forrest Addy
>I'm kinda guessing here but my experience with veneers is when I jointed one face then re-sawed a veneer and repeat. That way I got one flat smooth jointed face and one pretty good face but still bandsawed.
Seems to me I set the fence to the veneer thickness and never moved it until I got the veneers cut. I did have to fiddle a bit with the fence angle to split the band's natural "lead" - the slight out of parallelism inevitable in sharpening job.
If you re-set the fence each time you stand the chance of making a mistake or worse having the saw bite into the stock if it happens to drift away from the fence. It's less fuss to park the fence and saw the venwwers. Time and fuss is money, you know.
Bill Falberg
>Assuming you're set up to cut flat, straight, and true: you can do it either way, but doesn't it make more sense to set your fence to the desired thickness and repeat the cut until the material is all used up? Re-setting the fence for each cut seems like such an unecessary waste of time. Not to mention the introduction of microscopic differences in thickness from errors in measurement. It makes more sense to spend all the time you need to define the lateral and vertical vectors of the cut plane with your presumably flat, smooth fence. Once aligned, each cut should be identical to the last. This can be relatively easy or impossibly difficult, depending on your understanding of blade dynamics (set angle and pitch); and machine dynamics (tension, tracking, and alignment). If you can't make consistantly flat cuts the fence is irrelevant anyway. I have found that dust collecting under the workpiece can throw vertical alignment to the blade off enough on deep cuts to create wedges instead of flat veneers so I now rely on a flat, smooth fence of sufficient height to press the workpiece against as I feed it in. Make sure the fence itself is perfectly rigid.
Paul Waddle
>Thats how I see it too. Thats how I will do it! thks,pw
