Zinsser Shellac - why an age limit for use?
Tim Greif - West of Chicago
>I have a couple cans of Zinsser shellac, one clear bullseye and one SealCoat. I've used the SealCoat on a number of projects. I just noticed the warranty says "if used within three yeaqrs of manufacture". I also noticed that the Bullseye shellac says do not use if older than three years from the manufacture date on the bottom of the can. The SealCoat was made in 2002 and the Bullseye was made in 2006. Does this stuff really go bad? I seem to recall Michael Dresdner talking about this a while back but can't find that thread. I used the 5 year old SealCoat just a few months ago to seal up some galvanized pipe so it could be spray painted and it worked great for that.
Anybody have any advice on this.
Re: Zinsser Shellac - why an age limit for use?
Re: Zinsser Shellac - why an age limit for use? *LINK*
Bill Howatt
>Shellac does go bad. Attached is a link to an article by Jeff Jewitt which explains why it goes bad and simple shellac test. It also has much more good info on shellac.
Bill
Shellac Info.
Re: Shellac - age limit
>Tim,
Since Michael was involved in the development of SealCoat(TM), he can give you the authoritative particulars. I can tell you from direct experience that yes, the stuff goes bad over time because the resin becomes weak and finally will never set up as a hard film, but rather stays gummy and soft.
I don't use SealCoat(TM), a 100% dewaxed shellac made with a special proprietary process, but I do mix my own dewaxed from flakes. When I began working with waterborne finishes, I used dewaxed shellac as a sealer to prevent raising the grain with the water content of the top coat. I also used it for sealing any stain and toner I might have applied that could leach into the waterborne film. I got into a huge problem with a piece that developed what is called "cold checking" of the shellac where the shellac layer actually cracked like an old finish and followed through into the waterborne lacquer topcoat; a real mess. When I called the top coat company, Target Coatings, the owner [Jeff Weiss] told me that they were getting a number of complaints about the issue where shellac (including SealCoat(TM)) that was too old was used as a sealer. He indicated that, as a general rule, mixed shellac more than 3 months old or SealCoat(TM) more than 1 year old should not be used under his finishes, and even then, that it should be applied sparingly.
Hope this helps until Michael jumps in.
Well, I hope I'm lucky...
Denis Ch�nard, Orl�ans, Ont.
>...given the comments above...
I found in my basement a nearly full gallon of SealCoat that has a Feb. 2003 date of manufcture. I did not want to throw it away if it was still good, and I had a batch of maple moldings to finish, so I tried it on one board, and it behaved like brand new stock, dried in a hurry, no problems whatsoever.
Now I hope I won't get in trouble when I topcoat the moldings with waterborne poly...
DC
Since you've asked (long)
Michael Dresdner
>A couple of people have requested that I respond to this thread.
Shellac degrade:
As soon as shellac comes in contact with alcohol, which is its solvent, it begins a degradation process called esterification in which the shellac resins convert to shellac esters. The more esters are created, the slower the shellac dries and the softer and more prone to water spotting the final film is. This process occurs whether the can has been opened or not. Applying a fast drying finish that shrinks substantially over soft undercoats, including over esterified shellac, will cause cracking. In fact, old shellac is sometimes used this way in the motion picture and theater applications to mimic old finishes and paints. This may be what happened to Mark.
How long is it good?:
There is no absolute number, but several factors affect shellac aging. First is the cut. The thicker the shellac is, the slower esterification takes place. Therefore, a five pound cut of shellac will have a much longer shelf life than a two pound cut. How much longer? Depending on other conditions, about eight or nine times longer. In other words, adding alcohol to a can of shellac shortens its shelf life. Now, about those other conditions; heat, sunlight and moisture are enemies of shellac, even in flake form. Store in a cool, dry place away from sunlight. When shellac resin arrives at the Zinsser factory it is stored on shelves in a huge room that is actually a gigantic refrigerator. The bad news is that when you buy a can of shellac from the store, you may know how old it is by the date on the can, but you have no way of knowing whether it was properly stored during its travels, its stay at the warehouse, or its life on the shelf. Hence, shelf life remains a moving target and is not an absolute science, at least as far as we consumers are concerned.
What is SealCoat and how is it different?:
About six years ago a patent was awarded for a long shelf life shellac resin that substantially retards the esterification process. SealCoat is made from that resin, meaning it has a much longer shelf life than other shellac AT THAT POUND CUT. That's important, since the cut still matters. One big difference is that SealCoat is sold in a much thinner, lower pound cut formula, which is possible only because of the extended shelf life resin. Of course, storage conditions still matter also, as it will degrade, only more slowly.
Is five year old SealCoat still good?:
For most applications, if it was stored perfectly, probably yes. I tested some of the original lab samples five years out and they were fine, but to be fair, my storage conditions are ideal all year around. With different storage conditions, the answer may be different.
How can I tell if mine is still good?:
The easiest way is to do a baseline test. Take a known fresh sample of shellac that is cut the same as your questionable sample. Put a drop onto a piece of glass. Check it frequently tracking how much time it takes before it hardens completely, and ascertaining just how hard it gets by pressing a thumbnail into the cured drop. Do the same test with your material and compare both drying times and final hardness.
Incidentally, while it is wise to use only shellac that dries quickly and hard when employing it under other finishes as a sealer, you can use even softened shellac as a final finish. The coating will not be as durable, but it is certainly acceptable. I've seen companies sell lathe finishes that are shellac intentionally softened with the addition of large portions of wax, and these are considered quite appropriate for light use turnings, such as art pieces. As long as it dries in a reasonable amount of time, you can use it; just don't expect the same wear properties as from fresh shellac.
I hope this helps.
Question
Bill Tindall, E.TN
>why is the shelf life affected by the concentration (cut) of the shellac?
Re: Since you've asked (long)
John Veerkamp
>Thanks Michael, very informative.
John
stearic hindrance
Michael Dresdner
It is difficult to say, since in theory as long as there is enough alcohol to react it should not matter. However, we know from experience that this is the case. If I had to guess, the most likely reason would be stearic hindrance.
For those not familiar with that term:
We know that as coatings get thicker, the molecules within the mix simply have a harder time getting around, since other molecules get in the way. In fact, as liquids get thicker, they start to behave more and more like solids, and the molecules move around a whole lot less. It is both logical and apparently exactly what happens on the molecular level.
That interference is called stearic hindrance. In plain English, too many molecules get physically in one molecule's way when it is trying to link up with another molecule across the can who is a candidate for reaction.
What makes it worse is that molecules do not have things like GPS devices or online dating services to find their chemical mate. They must wander aimlessly, bumping into other molecules along the way until they hit upon the one they want to react with. Thicker materials slow down this random movement.
