Re: Opinions on Freud 3HP Router???
JEB
>I have one I purchased in 1998 specifically for that purpose (to make raised panels). I've been very pleased with it's performance, and for the price, you can't beat it.
It doesn't come with any frills, even the manual is very basic (at least mine was 10 years ago), but for what you save on the cost of the router, you can buy any accessories you might need.
Although it's probably one other larger routers, one feature I really like is the speed adjuster. It allows you to lower the speed for the large panel bits, but increase it for smaller bits in softer woods.
As we speak, I'm using mine to trim out the mortises in the legs for the workbench frame I'm in the process of building. I'd don't use mine out of the table very often, but my smaller router is a fix base unit (actually I have two, an old craftsman; and a really old all metal Stanley I purchased for $25 from a guy a few years ago (just had to have it)).
One suggestion I'd make, and eventually I'm going to get one for mine, if you are mainly going to use it in a table. Buy either a collet extension or one of those new add-on that allow you to raise the bit from above the table. While I can't afford the latter, I'm planning on buying the former before I do my next big project that I'll need to use the router in the table.
The one I'm planning on getting is the one from MLSC (http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/router_collet.html). While it doesn't allow you to raise the bit from above the table, it does allow you to raise the bit/collet high enough that you can change the bit above the table.
I don't think you'd be dissapointed in you purchase. I sure haven't.
Hope this helps...JEB
