I had the one you don't want...
Jim Rahbe, Bedford, TX
>Matt,
The black metal one is the Original Shop Fox Fence. I added it to an old Delta Clone contractor�s saw that I used to have. Compared to the fence that came with the saw, it was like night and day. It has rollers at each end that ride a rail, making it very accurate, very repeatable, and very ridge when locked down. I had the 50 or 52� model.
But, that is exactly why you don�t want to buy this fence. You can�t just lift it off the table. You have to slide it off one end of the saw. In my case, the right end was up against a wall, meaning that to remove the fence, I had to lower the blade and remove the splitter, and slide it off the left side. Even if I wanted to just move the fence to the left of the blade, I still had to lower the blade and remove the splitter.
The next reason you don�t want that fence is because it is impossible to have an out-feed table butted up against the saw itself. The rear of the fence needs to slide on the rear rail, which requires about five inches of clearance.
I believe that you would be much happier with a Biesmeyer style fence such as the Shop Fox Classic, or any other vendors with the same basic design.
BTW if you search in the Archived Messages, you'll see several posts on this subject..
Jim R.
